Hey,
I have 8000 miles on my 08 Z51, should I expect to have mild feathering on the inside of my front tires? I drive mostly freeway with minimal twisties. I seem to remember having a similar issue on my 1990 mustang. Was told that it was normal for the type of driving I am doing.
Any input?
From: Greater Detroit Metro MI, when I'm not travelling.
Originally Posted by biskitman
Have an alignment done and tell the person doing it to change the tire to ZERO camber. Vette setup seems to be setup on the inside of the tire.
Corvettes are setup with negative camber so they handle well. Aligning it for zero camber wil severely compromise lateral grip and will cause excessive outside wear when cornering. Even cheap commuter cars and minivans have SOME degree of negative cambler.
GM Engineers spend a LOT of time testing and calibrating the factory alignment to maximise performance under all conditions while still providing acceptable tire wear.
Also camber is not what causes most of the wear; toe is. If you want to reduce wear and still get good handling just set zero toe.
Get an alignment to factory spec (not within spec, but on spec)....My '08 was way outta spec in several areas. Figure they have 3 minutes on the assembly to make 10 suspension adjustments.
Normal driving with ocasional twisty forays will get you this at 9500 miles. The rears look even better:
[QUOTE=Modshack;1566250162]Get an alignment to factory spec (not within spec, but on spec)....My '08 was way outta spec in several areas. Figure they have 3 minutes on the assembly to make 10 suspension adjustments.
What, exactly, IS the factory spec?
Not this~
or this~
or even this~
but they can result in this...
and then driving in the rain with worn out tires causes this~
Cheap commuter cars may have some negative camber, but they do not have 12 inch wide tires. The wider the tires, the more camber will affect the wear.
Just sitting the toe-in to zero will not eliminate inside tire wear. I backed my negative camber down in increments and I had to get down to -1/8 degree before I got acceptable tire wear for street driving.
I don't think GM cares about tire wear. I think they set the cars up to handle with aggressive driving and just accept that tires are expendible. My theory is that with a lot of negative camber and aggressive driving, your tires will wear out just as quickly, but they will wear out evenly instead of just on the inside.
Feathering is a product of toe problems. Look which way the feathers are pointing. If they point toward the outside, you have toe out, and vice versa. Negative camber will make the feathering occour on the inside of the tire, 0 camber and the feathering will occour across the tread.
Feathering occours because the tire is not rolling straight ahead, but scrubbing slightly sideways.
This is the range. What is THE spec that Modshack alluded to?
The first number is the spec, the second the range. You can see that it is pretty broad...Try to get as close to the center as possible.
Here's my '08 before and after..
Do a search on this topic. I had the same problem with my Z51 awhile back. I had plenty of tire left on the meat of the tire and the inside edge was worn to the cords. There is some great info in that thread that worked for me.....Craig
A perfect stock alignment will eat the inside edge of the tire due to the camber dialed in. The camber is there for good cornering if you X-Cross or race on a road course. For driving around tracks like that, use the stock camber. For plain, drive it on the street and not in competition, set the camber down to -0.10. The other stock settings for caster and toe are fine to use. Simple as that.
Race? Jack in the caster.
Want the longest mileage from the tires? Set the caster to -0.10
