Any Help Appreciated
Old Jul 29, 2008 | 06:05 AM
jpeardm's Avatar
jpeardm
Default Any Help Appreciated
07 convertible, 3LT. I have had classic dead battery problems due to low mileage driving. New Optima coming. In the meantime, even after charging old battery to its max capacity, the drivers window and power top won't operate. Trunk release and pass window operate OK. I can hear a slight noise inside door as I operate the window switch but no movement of glass. Power top does not respond at all. Battery has been disconnected a couple times for a short period to see if anything would reset. I understand from the manual that these are run thru auto resetting circuit breakers, not fuses. Any ideas would be appreciated. Thanks.
Old Jul 29, 2008 | 06:18 AM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
The power top will not operate if the windows are not working properly.
If your battery was (completely) discharged, disconnected, or replaced, your windows may need to be re-indexed by doing the following:
Hope this helps!
Old Jul 29, 2008 | 06:34 AM
timd38's Avatar
timd38
Depending on how bad the battery was drained, it may not come back becasue the active material on the plates sulphates.
Old Jul 29, 2008 | 07:01 AM
jpeardm's Avatar
jpeardm
Hope this helps!
Thanks, I saw this in the manual but the window is in the down position and will not raise at all. ???
Old Jul 29, 2008 | 07:04 AM
jpeardm's Avatar
jpeardm
Yes, I'm sure the battery is toast, just opening the door triggers my auto charger to come on. I'm going to put a yellow top in and see what happens, just hope no mechanical problem with window regulator or something.
To Any Help Appreciated
