2005 C6 Powering Down Problem
Old Aug 3, 2008 | 03:38 PM
moekel's Avatar
moekel
1st Gear
Default 2005 C6 Powering Down Problem
After shifting to reverse and I turn the car off but it keeps telling me to shift to reverse - it already is in reverse but I take it out of gear and then put it back in again. Most of the time it turns off but today it didn't and then it killed the battery. What is going on?
Old Aug 3, 2008 | 05:01 PM
Wayne O's Avatar
Wayne O
CF Senior Member
Obviously, it seems like it's not getting the signal the transmission is actually in reverse and accordingly, not completing its shutdown routine (hence draining your battery). Take it to the dealership. It's probably just a faulty sensor or something...hopefully something simple.
If you re-charge or replace your battery, I'd disconnect the battery when you're not using the car until you fix the problem...no point draining and/or ruining the battery a second time. You will have to re-index your windows after re-connecting the battery.
Old Aug 3, 2008 | 05:20 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
Its probably a sensor as Wayne said.
I assume you have a 05 manual car or a export car
If your car has not had the procedure done to eliminate DBS get it. Check with a dealer
I had a 05 with many times DBS problems. I used to go into garage too far on purpose and then actually back up a few feet to be sure I had reverse.
PS the procedure number is PIC4188B
To 2005 C6 Powering Down Problem
