Decesions, Decesions
I have a 05, Z51 6spd with the following mods, Halltech intake, long tube headers 1 3/4, high flow cats, x pipe, Corsa Sports. I just purchased an electric water pump and a 160 stat.
The car is driven 3-4 days a week and I plan on tracking it 3-4 times a year, time permitting. My goal is to get to 450-500rwhp and retain most of it's driveability some cam shake is ok.
I can't decide if I should stay with my set up and just improve on it, i.e. get my heads worked on, cam, intake and throttle body ported, and underdrive pulley all of this with a tune obvisiouly.
OR
Do the same but via L92/L76 setup.
I now I can do it either way but which is MOST COST EFFECTIVE. Money is a little tight right now as I am starting a new business.
Input from tuners, forum members that have either your advice is welcome.
From one car nut to another thanks ahead of time.
And no NOS for me.
Is that to say that the L92 set up is more cost effective? Meaning you don't think I can do it with a ported fast/throttle body, cam, underdrive pulley?
Just playing devils advocate, but on a serious note dollar for dollar which is the way to go? And why?
Thanks ahead of time.
If your choices are ported FAST vs L92/L76 well that's a little different. A ported FAST + cam and bolt ons should get you in the 430rwhp range. You can then save up for a set of heads and hit 470-500rwhp. If you go with an L92/L76 + cam and bolt ons you could hit 460-470rwhp right out of the box. Then if/when FAST decides to make an intake for the LS3 you can get that and probably hit your 500rwp then. They are all good choices. It just depends on your finances and future goals.
To recap:
H/C + FAST will get you close to 500rwhp but is expensive.
L92/L76 + cam and bolt ons will get you 450-470rwhp and is comparitively cheaper than the above option.
FAST + cam and bolt ons (no head work) will get you 430+rwhp for a little less than the L92/L76 swap.
Looks like the L92/L76 with appropriate cam is the way to go.
As opposed to getting my 243 heads ported and and cam.
Since I have your attention do you think I can do that (L92 setup) with out fly cutting pistons or am I being cheap and I should just go ahead and do it.
And is it worth porting the L76 dollars to horse power wise.
Thanks brother,
cya
Thanks for the info. Gland to hear the weather is getting better for you, Gustav is heading to Gulf of Mexico. I'd love to hear more about your car i. e. bolt ons etc.
And can I ask you cam specs and will you be needing to fly cut, also do you plan on exhaust porting before install?
I'll be doing this in parts as I just spent $925. on a set of F1 super cars for the rears. I have the Zo6 quarter panels. It's lowered, I get many compliments. I'll post pictures once I figure it out get the car washed and have some time.
Thanks ahead of time brother,
CYA
CYA,
We are not sure about rather or not to fly cut....the clearance will be checked upon installation. However, according to forum member the clearance will be in question with this cam. I'm trying to keep this project cost effective, so the exhaust porting is not on the menu for right now. Here are the specs: 224/228 .581/.588 114 LSA. Just keep an eye on my next post regarding the installation results.
L92/L76 Thread
Too bad you guys aren't close. I'm not mechanicaly inclined but I guess I could save money and sell my old parts.
Question can you give me a ball park of what a shop should charge for the install and fly cutting if needed.
Thanks ahead of time,
CYA
