External Oil Cooler ---Help!!!
I need some help with an overheating concern.
I am having a Procharger D1SC S/C installed on my 2008 Z06 this week. I have big concerns about overheating when road racing (hobby type racing). I have added a Dewitts A05A radiator and a 160 stat. I have not added the optional double fan for the Dewitts.
My questions is whether anyone has added an external oil cooler with a similiar set-up and what brand and where was it mounted. Did the oil temp come down to a reasonable level?
I have heard of Fluidyne, B&M, and Moroso but not sure if there are others, which are the best, and which may be the best for my specific situation. The car will be a daily driver 90% of the time and a road racing maybe times per year.
Please Help!!!!!
Thanks,
Paul
Secondy, I have read alot about the mixture (liquid) within the radiator. Any suggestions there and will it be too much, not enough, worthless, when on street or track.
I am just not sure if this makes any sense at all but I have been told given my current set-up I will approach dangerously hi-temps after 2-4 laps.
I want to solution to be effective and reliable.
Any help is appreciated. It seems mine is a common problem and there seems to be no clear cut solution.
Regards,
CPG
Regards,
CPG
As far as the mixture, replacing the coolant for water on your radiator will dramatically increase the heat capacity and cooling capacity of the system. You can't run pure water, as it won't protect the engine from corrosion, but if you run mostly water with some water wetter you will see dramatic reductions in the coolant temps. And since you live in Florida you can do that without worrying about it freezing in winter.
Another thing to think about is heat management within the engine. Headers will reduce backpressure, lowering the boost your engine sees; it will get better gas mileage and make more power at lower boost, so the intake air temperature will go down and the heat load on the intercooler will go down as well. Ceramic coating the headers will also reduce under hood temperatures, again helping keep everything cool.
For the oil cooler location I would not hesitate to mount it on the front of the car; yes it will be blocking some of the airflow to the intercooler and radiator, but that is not a real issue at a kind of speed when the airflow into the front of the car is in the several tens of thousands of CFM.
As I indicated - I have added the A05A Dewitts which does have the intregral engine oil cooler but not the transmission cooler. Do you believe the add-on dual fan will have an effect or make enough of an impact to cool my engine oil to an acceptable level. Is it really worth the extra $$$. And finally - will it physically fit given I already have installed the D1SC with the intercooler?
This is very fun, ie., learning new things but there does not seem to be a clear cut way to solve the problem year round and from street driving to road racing. I thought adding the Ext cooler with a valve to remove trom the loop was a grand idea. Bu I will be the 1st to admit - I know nothing!
It's actually the other way around....
A05A has the tranny cooler, on the right side, metric ports.
the A05AE would have both, and the A05E would have the EOC only on the left side, O'ring ports.
PS. DRM offers nice external package complete with hoses and brackets.
I then made a final decision to at least give road racing a try and spoke with Henry Gilbert. He indivcated an EOC is a must!
Given I have all the related S/C components packed up front where would you suggest I place a DRM or alike? Further, as I have an understanding (wrong or right) that an EOC may cool too much outside of racing. Would a cut off valve feeding the EOC be a reasonable idea?
I do not need to do the EOC immediately but certainly feel it should be done prior to road racing. Finally - would the dual cooling fan do me any good?
Thanks,
CPG
Thanks,
CPG
Tom:
I found the DRM 30-678 and it looks relatively small. The final question would be whether or not your A05AE has the capacity to cool my car during road racing?
Thanks,
Paul
I will call you first thing Thursday morning.
San
I appreciate all the comments and help. I will sit down with my shop whom I have yet to really push on this subject and come up with a solution. I have a mechanical mind but there are just to many variables.
We do sell the kit with either the Setrab 619 or the Setrab 625. 619 (13inch wide, 5.75 tall and 2 inch thick) The 625 (13 wide, 7.5 and 2 inch thick). They also make up to 18.5 tall, which is huge. Get them to fit inbetween a big radiator and a intercooler is not a fun task. There just isn't a lot of room as you know.
Superchargers and road racing just don't work that good together. Intercooler in front of the radiator, and the mass amounts of power that the engines are making. One must look at the amount of power needed to spin the compressor and add that to the "heat" made from the engine. So if you make 550 RWHP, That is about 640 or so to the crank, then if the supercharger takes 100 to spin. The engine is making the heat of a 740 engine. How many road race cars are making 740. That is more then Nascar, indy car, trans am cars, WC cars, ALMS cars, and many others. Flat out T1 guys have problems keeping things cool during a 40 minute race, with 400 horsepower.
Randy
Randy
I have quickly come to this realization. My only possible option is to purchase another Vette for strictly road racing.
Now I just need a bigger garage
Randy
San
Randy
Can I mount a Setrab under the wheel well? Not sure if the Setrab has a thermostat but certainly I can add a thermostat "module" downstream? I have access to a very capable machine shop so making custom bracketry is not an issue.
Another comment I have received is the oil sump may not be sufficient in general for road racing? Something about "banking on the curves" not allowing oil to circulate????
