Kooks Header Question
Old Sep 21, 2008 | 01:02 AM
gibear2k5's Avatar
gibear2k5
Default Kooks Header Question
I have a 2008 M6 with the NPP exhaust option. I plan on purchasing the coated Kooks and catted X-pipe, will they bolt up to the stock NPP cat back? Or do I also need to upgrade the cat back exhaust?
Thanks -
Old Sep 21, 2008 | 02:00 AM
JayplaySS2's Avatar
JayplaySS2
Thanks -
I just installed the Kooks 1 7/8's with the 3" x 3" Xpipe and it bolted up perfectly to the factory tailpipes, which are the same as yours Im sure. Easy install. I would say get the 3" x 3" though since the last 24" is 3" instead of the 2.5" EVEN THOUGH both neck down to 2.5" right at the tailpipes. You'll gain atleast 1-2 rwhp..LOL
Old Sep 21, 2008 | 02:02 AM
3 Z06ZR1's Avatar
3 Z06ZR1
Thanks -
Get the 3 by 2 1/2 x-pipe works better than the 3 by 3 with a reducer
Which is your other choice!
Old Sep 21, 2008 | 02:40 AM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
the 3"x3" AND 3"x2.5" BOTH neck down to 2.5". both will fit the stock NPP exhaust. the ONLY midpipe that is 3" all the way is the ZO6 midpipe.
-Carl
Old Sep 21, 2008 | 03:22 AM
gibear2k5's Avatar
gibear2k5
Quick response, thanks! I feel at ease again.
Old Sep 21, 2008 | 07:13 AM
Ron Cannella's Avatar
Ron Cannella
Have the 1-7/8 with 3" Xpipe and hi flo cats great system bolts right up . BUT NOTE DO NOT USE KOOKS GASKETS ON HEADERS USE ORIGINAL GM AND YOU WONT HAVE ANY PROBLEMS.
Old Sep 21, 2008 | 07:35 AM
carlrx7's Avatar
carlrx7
whats wrong with the kooks gaskets? i used them. dont notice anything out of the ordinary
-carl
Old Sep 21, 2008 | 08:16 AM
Corpsvette's Avatar
Corpsvette
Veteran: Marine Corps
I am gonna do some hijacking here. Doesn't the new 08's come with an X-pipe. Can it be used or do I have to have a new x-pipe to make everything line up properly?
Old Sep 21, 2008 | 08:54 AM
gibear2k5's Avatar
gibear2k5
So, it probably wouldn’t be a bad idea to get with Mr. Gene Culley and order some new gaskets and head bolts?
Old Sep 21, 2008 | 10:12 AM
carlrx7's Avatar
carlrx7
ok.. cancell my last post of why use the supplied gaskets instead of the GM ones.
i didn't believe all the hipe. and just when i was gonna open my big mouth and brag about my kooks gaskets working fine. i went out and took on last look. leaking like a sob!! so about 1 hour of my life wasted swapping them out. and here is proof. 1000miles later
reason 1,920,922 to reuse stock GM gaskets!!
-carl
p.s. and yes, they were all torqued to spec using my craftsman tq wrench!!
Old Sep 21, 2008 | 11:09 PM
3 Z06ZR1's Avatar
3 Z06ZR1
-Carl
What? 3 by 3 is well 3 by 3 Too big for 2 1/2 pipe
Without a reducer!
3 by 2 1/2 perfect fit. Where in the world did you get that
Old Sep 22, 2008 | 01:02 AM
carlrx7's Avatar
carlrx7
Without a reducer!
I got it straight from the horses mouth. KOOKS. i originally wanted a 3x3" pipe to match up to my z06 exhaust, which is 3", they said it reduces down the last 12" to 2.5".
please stop spreading the wrong info,,
i know the numbers dont look right, but thats how it is.. any c6 midpipe will work, only the z06 midpipe wont fit. the 3x3" is NOT the z06 midpipe.
-carl
Old Sep 22, 2008 | 04:13 AM
3 Z06ZR1's Avatar
3 Z06ZR1
I got it straight from the horses mouth. KOOKS.* i originally wanted a 3x3" pipe to match up to my z06 exhaust, which is 3", they said it reduces down the last 12" to 2.5".* please stop spreading the wrong info,,* i know the numbers dont look right, but thats how it is..* any c6 midpipe will work,** only the z06 midpipe wont fit.* the 3x3" is NOT the z06 midpipe.-carl
Z0-6 takes the 3 by 3 X- pipe to work with the 3 inch catback. 3 by 2 1/2 X pipe fits the 2 1/2 pipe on a c-6. There is NO part of the 3 by 3 that is 2 1/2Got it straight?
Old Sep 22, 2008 | 05:32 AM
carlrx7's Avatar
carlrx7
ohmigod, you are so wrong. z06 take the Z06 midpipe, totally different part.
Z06 Midpipe: Part #: K6611S
http://marylandspeed.com/kooks-3-x-3...11s-p-874.html
c6 midpipe 3x2.5: Part #: K6608S
http://marylandspeed.com/kooks-3-x-2...08s-p-748.html
c6 midpipe 3x3: Part #: K6609S
http://marylandspeed.com/kooks-3-x-3...09s-p-749.html
Note the different part #'s
either way, 3"x2.5" or 3"x3" will work on his ls3 and NPP, as long as he doesn't get the z06 midpipe.
just give kooks a call, they will tell you the EXACT same thing. im done with this. ill accept apoplogy's in the form of PM's.
-carl
Old Sep 22, 2008 | 09:55 AM
3 Z06ZR1's Avatar
3 Z06ZR1
ohmigod, you are so wrong.* z06 take the Z06 midpipe,* totally different part.Z06 Midpipe: Part #: K6611Shttp://marylandspeed.com/kooks-3-x-3...11s-p-874.htmlc6 midpipe 3x2.5: Part #: K6608Shttp://marylandspeed.com/kooks-3-x-2...08s-p-748.htmlc6 midpipe 3x3: Part #: K6609Shttp://marylandspeed.com/kooks-3-x-3...09s-p-749.htmlNote the different part #'seither way,* 3"x2.5" or 3"x3" will work on his ls3 and NPP, as long as he doesn't get the z06 midpipe.just give kooks a call, they will tell you the EXACT same thing.** im done with this. ill accept apoplogy's in the form of PM's.-carl
* X pipe 3 by 3 fits 3 inch catback so if his pipe is 3 inch,thats what he needs. 2 1/2 tail pipe like on mine needs the 3 by 2 1/2.
Old Sep 22, 2008 | 09:58 AM
3 Z06ZR1's Avatar
3 Z06ZR1
-Carl
One has 2 1/2 outlet for 2 1/2 catback.
PERIOD. One has 3 outlet for 3 inch catback. Zo=6 for Z-06 cars!
Old Sep 22, 2008 | 10:16 AM
wbear's Avatar
wbear
-carl
Acording to the links you posted you are going to owe the apology. Links 1 and 3 both have 3" inlet and outlet. One is for the Z06 and one is for a C6 with a 3" aftermarket catback. 2.5" is not mentioned any where in the description. If a person had a 3" catback why would they want any part of the system 2.5"?
Link 2 has a 2.5" outlet and fits all C6 with a factory exhaust or 2.5" aftermarket catback.
I'm confused. If the 2 links state they have a 3' inlet and outlet why would you think one has a 2.5" outlet?
To Kooks Header Question
Old Sep 22, 2008 | 10:28 AM
3 Z06ZR1's Avatar
3 Z06ZR1
Old Sep 22, 2008 | 05:33 PM
carlrx7's Avatar
carlrx7
OK OK One last post..
i found my EMAIL FROM Maryland Speed that talked straight to KOOKS.
----EMAIL-----
Dear carl
I talked to Kooks, and to connect to the Z06 Exhaust, you will need the 3" Z06 X-pipe (PT#6611S). I can switch this out at no additional cost.
The reason is-
C6 X-pipe 3" x 2.5" (PT#6608S) necks down in the middle to 2.5"
C6 X-pipe 3" x 3" (PT#6609S) that you ordered necks down at the very end right before the axleback to 2.5"
Z06 X-pipe 3" x 3" (PT# 6611S) is 3" all the way through and will fit a regular C6 w/ a Z06 exhaust.
I know it is confusing, but it will work. Also, I would recommend skipping coating the X-pipe. There is no advantage to it, and it actually makes the slip fits really hard to get togethor. Let me know what you want to do.
I know it sounds confusing, but trust me on this.
---EMAIL----
READ IT A WEAP!!
But just keep saying stuff that your not 100% positive about. everyone is an expert according to themselves.
so please prove me wrong and just call kooks and get your pe-pe slapped. good day
-carl
p.s. i too was as stubborn as you are now and it shows as i tried to order the 3x3 to bolt up to my z06 bi-mode exhaust, but that was months ago, and i have learned and since have tried to pass on the CORRECT info. it would be nice if they updated their website so this stuff stops happening.
Old Sep 22, 2008 | 07:21 PM
3 Z06ZR1's Avatar
3 Z06ZR1
----EMAIL-----
Dear carl
The reason is-
---EMAIL----
READ IT A WEAP!!
-carl
read your OWN links for christ sakes. You still don't know what your talking about. The link says 3 by 3 inlet and outlet. Z0-6 3 inlet and outlet. 3 by 2 1/2. 3inch inlet 2 1/2 outlet Whats sooooo hard to understand. I know these things because I installed my own stuff.
You apparently don't or you would have a clue!
