Engine Drag Contron
Old Sep 21, 2008 | 11:30 AM
C6Coupe's Avatar
C6Coupe
Default Engine Drag Contron
While trying to beat the light in a left hand turn, I down shifted pretty hard, and all of the sudden the vette just accelerated for a split second and the Message "Engine Drag Control" came up on the DIC.
Is this Normal?
Old Sep 21, 2008 | 12:19 PM
Finster07's Avatar
Finster07
Old Sep 21, 2008 | 12:36 PM
patton's Avatar
patton
St. Jude Donor '09
its normal but your driving wasnt
Old Sep 21, 2008 | 02:28 PM
C6Coupe's Avatar
C6Coupe
Thanks Mr Fitzgerald, ill try to do better
Is this the tech section or the driving school section?
Old Sep 21, 2008 | 03:16 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Is this Normal?
You made a bad driving mistake; your downshift during the turn caused the wheels to decelerate more than you had traction for, effectively doing what would happen if you had pulled the handbrake mid turn. Your car's wheel speed sensors detected that and the driving aid nanny stepped in and accelerated the engine to prevent rear wheel lockup which would have you spinning out of that turn out of control.
Proper downshifting requires rev matching; blip the throttle with the clutch down so that the engine revs match the RPM for the gear you are downshifting into; this will make your downshifts much smoother and prevent this problem from re-occuring.
As patton said; the car's behavior was normal, but your driving wasn't. In a lesser car without engine drag control you would have wrecked.
Old Sep 21, 2008 | 04:57 PM
C6Coupe's Avatar
C6Coupe
Thanks, that sounds logical, and seems to explain My question. Ill try to avoid that again
Apology's to Patton,thought You were being a smart azz
Old Sep 21, 2008 | 07:53 PM
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
If you weren't thinking of Shotzee and Doggie Girl, you'd be more careful.....
Old Sep 21, 2008 | 08:48 PM
C6Coupe's Avatar
C6Coupe
Old Sep 21, 2008 | 08:59 PM
MarkRx's Avatar
MarkRx
i'd downshift in a turn in lieu of popping the clutch to initiate a drift, like around a rotary, or after ordering from the menu at mcdonalds and turning left to pull up to the drive-thru window
Of course those days are over and none of this applies to the vette.
Old Sep 22, 2008 | 05:29 PM
PowerLabs's Avatar
PowerLabs
I just push the gas down when I want to "drift".
Of course, making 518foot pounds of torque at the rear wheels helps
Old Sep 23, 2008 | 07:34 PM
Mad*Max's Avatar
Mad*Max
I've gotten this message in the same location a couple of times - while having the engine decelerate the car going downhill on an overpass - never saw the message anywhere else.
To Engine Drag Contron
