Check engine light is on
Old Nov 1, 2008 | 10:49 PM
csilvette4's Avatar
csilvette4
I get the ck.eng.light sometimes after excelerating to fast, i purge the gas cap and it goes out.
Old Jan 20, 2009 | 08:55 PM
teuhl's Avatar
teuhl
I had a Callaway Honker installed yesterday and the engine light came on after driving home. I returned to the shop that installed the CAI and the fault was caused by the volume of air being out of the limits. This occurred when the car was stopped and the cooling fan came on reducing the air to the engine. This apparently has occurred only on some of the 2008 C6's. Callaway had a fix for this problem that was installed to correct this on my car. I drove 40 miles back home and did not experience the engine fault. I would recommend contacting Callaway if you have this problem. In regard to determining what is causing the fault, I understand you can call OnStar and they can run a real time diagonostic.
Old Jan 20, 2009 | 09:04 PM
johnodrake's Avatar
johnodrake
Moderator
Originally Posted by PAUZAO
I went to Autozone, but they said that the policy now changed, and the can no longer scan the PCM for free, or even for a charge. They said that I would need to buy a scanner.
Buy a scanner, they are cheap!
Old Jan 22, 2009 | 04:02 PM
mcv's Avatar
mcv
I had the same issue with my Honker on my 08 LS3. I contacted Callaway, but they could not help. The Mass air flow sensor on the 08's is a lot more sensitive than previous years. I checked my system, and although do not think that this was the issue, but the rubber cuff that goes over the lid was mangled, and I found a flat spot on the mass air flow adaptor. Callaway replaced the items under warranty. I have since then gotten my car tuned. Also check the your mass air flow sensor is pointed towards the correct direction.
Pauzao,
I wonder if it is "the same issue". I don't think we have enough info yet to make that call.
Did you still get the "Check Engine" light after you replaced the rubber cuff and MAF sensor housing?
Old Jan 22, 2009 | 04:10 PM
mcv's Avatar
mcv
Could you please tell me whether there were any drivability issues and what the "fix" was. We don't know who your shop contacted at Callaway, but we haven't identified coolant fan airflow being a problem for naturally aspirated Honker applications.
Old Jan 22, 2009 | 04:12 PM
PAUZAO's Avatar
PAUZAO
HI Mike, I sent you an e-mail. Please look at post 22, as he and others have experienced the same issues with the Honker and the 08 MN6.
Old Jan 22, 2009 | 04:30 PM
mcv's Avatar
mcv
Originally Posted by pTr73
Ok I took my car out tonight, drove for about 30 minutes, had the car off for a while then started it back up. I noticed my check engine light is on. I have a honker in my car, I havent had any problems with the light coming on. I did drive in the rain yesterday so I am wondering if that is the cause of this? Being that the rain can get into the filter since the shroud has a hole in it. I am gonna take it to a dealer and let them check the code. Any thoughts? Thanks!
Hi,
Rain wasn't the problem. We've driven test vehicles in deluges, snowstorms, and simulated storms and never triggered a diagnostic trouble code.
When was the Honker installed? Did the engine run any different than normal? Please let us know if you get the PCM scanned.
Old Jan 22, 2009 | 04:40 PM
mcv's Avatar
mcv
I just responded to your email. I'm concerned, but I'm just not ready yet to call your situation, teuhl's and pTr73's issue "the same issue".
You mention others. Do you know of others with Honkers who are triggering "check engine" lights, so we could do some investigation here?
Old Jan 22, 2009 | 04:58 PM
PAUZAO's Avatar
PAUZAO
Mike, I replied back. This issue is mostly with 08 cars.
Old Jan 23, 2009 | 08:38 AM
mcv's Avatar
mcv
Got your reply. You mention here that "This issue is mostly with 08 cars". Other than the two people posting here, do you know anyone else with a Honker that got check engine lights after installation. If so, I'd like to contact them. If not, I don't want people to think there's an issue with the Honker, if there is none.
Thanks.
Old Jan 23, 2009 | 11:49 AM
PAUZAO's Avatar
PAUZAO
Thanks.
If you search the forums, you shal find more related posts.
Old Jan 24, 2009 | 10:14 AM
mcv's Avatar
mcv
I've searched. Can you please point me in the right direction?
Thanks.
Old Jan 24, 2009 | 10:45 AM
  #33
mcv's Avatar
mcv
Thanks for calling and filling me in on the details. I also talked to your installing shop to talk about the "kit". It sounds like they encountered a phenomenon we've only seen with our supercharged Callaway Corvettes that we build in-house. The Honker system has such low restriction that the coolant fan's airflow can be detected by the MAF sensor. We haven't seen this as an issue with naturally aspirated applications, but with the PCM calibration we use with our supercharged cars, we had to compensate for this.
The issue isn't so much that the fan "reduces" the airflow to the engine; it's that the PCM expects to "see" certain values from the MAF sensor under certain conditions and, when the fans come on, it sees unexpected output. So it triggers a check engine light.
It turns out that the "Kit" your shop used was some parts from the Honker system that we build for MagnaCharger applications. These are standoffs and fasteners to lift the Honker filter element base from the radiator shroud surface. For supercharged cars, the cold air access hole is not cut into the radiator shroud.
This is only an idle-related condition. We haven't seen surging result from this situation. People experiencing surging with the check engine light may be having an unrelated problem.
By the way, you selected an excellent shop to work on your car. Reese *** and his guys at MTI Racing do an excellent job.
I'll have more on this during the week when I'm back in the office. If anyone else has experienced the check engine light right after installing the Honker in an LS3 or LS7 (and the fans cycled on), and hasn't called Callaway about it, I need to know so we can have a proper response.
Old May 19, 2009 | 08:34 PM
  #34
teuhl's Avatar
teuhl
Today I had the Callaway diffuser installed to mount the Honker as originally designed. No problems!!! While at MTI Racing in Atlanta, I had a low temperature thermostat installed. Reese made adjustments to the fan controls to work in conjunction with the low temp thermostat. Temp is reading less than 180 degrees with outside temp in low 70's. I am more and more impressed with the MCI Racing organization upon each visit. Highly recommend for your upgrades.
Old May 19, 2009 | 08:58 PM
  #35
pTr73's Avatar
pTr73
Hi,
Sorry this took so long for me to respond, I didnt see this post until today. I didnt think rain was the culprit, I had 3 incidents with the check engine light coming on, the first 2 times i disconnected the battery and it went away... The second time I left it alone and it went off on its own. I do remember travelling over bridges before they came on (250ft above sea level). I know this might sound silly but do you think the air pressure that high might affect the MAF being that its sensitve? I am going to take the car to work tonight (going over the bridge and see if I get the light again.
Old May 20, 2009 | 08:36 AM
  #36
mcv's Avatar
mcv
Atmospheric pressure between sea level and 250 ft. above sea level isn't that different, so I don't believe the altitude is affecting MAF sensor input. There are Honker owners in mountainous regions with much greater variations in daily driving.
Is the road surface on the bridges solid, or is it made of steel grating where high winds could come up through the road surface and cause high turbulence under the car?
Old May 20, 2009 | 04:20 PM
  #37
pTr73's Avatar
pTr73
No grating as far as wind turbulence getting under the car. The road surface was a bit bumpy in places (maybe jostled the MAF a bit to cause an error IDK). I try to look at every possible reason even if they seem far fetched.
Regarless of any glitches which I know it isnt the honker itself. I am still 200% satisfied with design and quality of it. Which is why I chose it over all the other aftermarket CAI's out there.
BTW where can I get a replacement filter? Or do I wash the one I have in the car now?
Old May 23, 2009 | 11:31 PM
  #38
mcv's Avatar
mcv
You can either wash and reoil or replace the filter element.
Callaway sells replacement filter elements and K&N filter cleaning kits.
You can go to the Online Store on www.callawaycars.com or call us at 860 434 9002.
