Trick Flow 225 on a LS2 issues
I was not saying that his dyno number are wrong, fact is dyno numbers vary from shop to shop, as do results between 3.42 gears (Bills Dyno) and 4.10s (my dyno).
I was not saying anything about his tuner, their capabilities or advice. I was not implying that my car was better than Bill's, but that I achieved very close to what he originally wanted at a fraction of the cost, and my power comes on faster down low where he wants to feel it. He is probably feeling that 20 or so dip in torque around 2600 rpm, and since he is only a street driver, he never really had his revs up high for very long. Bill and I are friends, we've been in each other's cars. What many reading this do not know, is that the saga of Bill's H/C job left him unhappy on many fronts ( you can search out the threads to see what I mean). His threads have shown his frustration time and time again.
He wasn't happy with the original thrust off the line, he felt the car was a dog. He added the expense of the 4.10s, and he still wasn't happy. A few months later, he posted if AFR heads would be better for him because these heads were too noisy. He was also upset at all the money he put into his car and still did not get it to perform they way HE wanted it to.
Knowing how much he liked the way my car performed even before the H/C job, I was offering another possibility where he may be able to achieve exactly what he wants, without spending another $2K or so on the "chance" he may be happy. If he could get the exact feel and performance he wants without having to spend a lot more, perhaps this was an option he could consider...that's it..nothing more.
The Trick Flows are suppose to be great heads so might as well keep them
Thanks for helping
By the way, I have Trick Flow 225's on my LS2. They are not milled and I have the stock gasket thickness. I have a Crane 228/232, 600/600, 112, +5 cam that has what Spin descibes as "lazy lobes." I also have 1 7/8 inch header primary tubes. Each of these choices is suboptimal for torque. I also asked my tuner to cut the power from the original head/cam tune because I spun my stock tires so much that it was not fun to drive anymore. I have no A/F ratio above 12.5 in any 100 RPM cell. I don't know about the timing. I am a dummy, too!
Anyway, my dyno graph shows that we are +/-5ft lbs at 2,500 but by 3,000, I have 40 ft lbs more! I have just a little more at both 3,500 and 4,000. There seems to be something wrong for you at 3,000. We are close before and after that but you are way off at 3,000. You may want to ask the tuner about this point. I have stock 3.42's, by the way.
Also, my torque peak is at about 4,700. Yours seems to be at about 5,300. This might be due to my 112 vs your 114 and my +5 advance. What is your advance? If you have an adjustable timing chain, you might be able to advance the cam and trade some peak for a little more bottom end.
I don't think there is anything wrong with your heads.
I never posted a dyno sheet of any of my builds but the results on Craig's car are confirmed when you drive it. If you drove Bill's car, you wouldnt think it had a 2500 dollar set of heads (plus the 400 for the rocker arms to use them). While I dont think the L92's are the be-all, they are cheap. Complete with valves and springs they were about 875 bucks for the pair with a 228 cam, not 3k for a trick flow set of heads. If the cost was set aside, the trick flow heads are far beyond the L92's in performance and you dont need to flycut.
Maybe Bill should jujst drive Craig's car and then he will know for himself what 460rwhp feels like.
A last note: Craigs numbers were throught 4.10 gears and Bill's dyno sheet was through 3.42's. The 4.10's were added after the complaints about the power level were relayed to the tuner. 4.10 gears and same dyno would take the usual 10-12 off the peak HP and 8-10 off the TQ making it 443hp and 407rwtq? Maybe thats the issue
In the tuner's defense Bill asked for a mild set-up, so telling the tuner there isnt enough power coupled with having asked for a cam with certain driving manners isnt so fair either. That tuner has built sick cars and has 2 of the most crafted mechanics (GMcertified too) that there are. They can definitely build a fast car. Ithink these after the fact comments are clashing with the initial requests made of them.
Please do not think i am comparing any results from my builds to this one. It was craig who posted a dyno for his car and not me posting them for any of my builds. Mine has higher number results through 4.10's with the same cam and heads but I'm not posting it because like the last time i tried to help with this exact same car, it became a Spin hate post. Bill asked me for my opinion and got it. Any other correspondence on this topic will be ignored by me because of the nasty grams I'm getting.
However, I don't feel sorry for Bill if his forum name is correct. If all he ever gets is par 3's, 4's, and 5's, he's a heck of a golfer!
I really like this forum. All this discussion and everyone always had a very level head. Just trying to help out the OP with his car. There are a bunch of very generous people on this forum!!!
What would be an amazing tool, is if someone could make a very accurate simulator for the PC, PS3, Xbox etc that would allow you a driving simulation of road, 1/4 mile highway conditions to see exactly how mods would work by imputing the exact characteristics of your car. You would think with all the car simulators out there now, it could be done.....and whoever does will make a boat load of money for sure.
I would bet you would be ready for my newer cam now. Its only 2 degrees more and will lope slightly more yet have more power everywhere under the curve. Want to see 480rwhp? Did I say its free?
I have alot of friends with cars that smoke tires and I constantly hear them come back from a race that they didn't hook up etc... of course when they lost the reasons fly but its true. My car now breaks the tires with the 410's but only for a short priod of time and then launches as you said it roars in the higher rpms's i will see if Vette Doctors can give me alittle more low rpm power and maybe put some money in the bank
If I had it all to do over again, given that I am more interested in low end performance, I would have just went with a Maggie from the get-go.
However, what's done is done, and I am very happy with my Vette's performance now (but I do think a Stage 3 Blower cam would have better suited my current set up versus the Stage 2).
410 gears. how much lower do 410 take away
indication loss on a 500 rwhp car . They give you so much performance
otherwise. The good folks on CF will help you achieve acceptable results
and you will be happy.
