Old Mar 27, 2015, 12:54 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: General How-Tos
Print Wikipost
reset oil light
Old Nov 10, 2015 | 04:36 PM
CCrane65's Avatar
CCrane65
That worked like a charm. Now all I have to do is remember it. And why isn't that in the owner's manual?
Old Nov 10, 2015 | 10:06 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Glad it worked for you.
I'm told it's considered a maintenance diagnostic procedure, buried in the Service Manual somewhere, along with the three buttons to push on your climate control panel to force an immediate outside temperature update.
Old Nov 12, 2015 | 06:38 PM
CCrane65's Avatar
CCrane65
Ah, the service manual. I have an old version of GM SPO but as I recall it stops at 2005. I'm down to 1 car that I can still use it for and that's my '05 Grand Prix GXP.
Going to need to purchase a CD or something for the C6.
Thanks Gearhead Jim.
cc
Old Nov 12, 2015 | 09:33 PM
owc6's Avatar
owc6
It is. It's called the service only mode. It's basically the same as the "on" on a keyed ignition. Don't count on it timing out and turning off like the Acc mode, so a dead battery is possible.
Old Nov 14, 2015 | 11:39 AM
CCrane65's Avatar
CCrane65
I searched the 2008 owner's manual for service only mode but it was not found so I searched for all instances of oil life until I found the reset procedure. I does not say anything about putting the system into "on but engine not running". It just says to press the trip button until oil life percentage is displayed then press reset for 2 seconds.
At any rate, I now know 2 ways to reset the oil life monitor.
Thanks again for all the info.
cc
Old Apr 14, 2016 | 05:48 PM
godzilladude's Avatar
godzilladude
Just to do it one more time:
Hold down the bottom of the start button for five seconds, and the car comes alive but doesn't start;
Push the "TRIP" button a few times, to get to oil life (had to hunt around for that);
Push and hold down the "RESET" button for a few second;
And POOF, back to 100%!
