Did I get slower?
Old Nov 4, 2008 | 08:47 PM
  #61
oneblackvette's Avatar
oneblackvette
Originally Posted by BOB EAGAN
No change needed for tire sizes?
YES small changes for tire sizes
NO changes for any gear change
Old Nov 4, 2008 | 09:06 PM
  #62
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
Originally Posted by oneblackvette
I though I would throw a wrench into this thing,
2006 C6 M6 3:42 375RWHP 355RWTQ ran best 12.5
2007 C6 M6 3:90 475RWHP 440RWTQ ran best 11.90
2001 996TT M6 AWD 507AWHP 550 AWTQ ran best 11.40
All on street tires and same days for the most part.
Yet repeatedly none of these can pull away from another during a roll on from 25 MPH to 100 MPH.
Well we can throw the Porsche out the window right away. Rear mounted engine, AWD, too many differences effecting the performance to compare it to a C6 for this particular argument.
As far as the other two, I think a roll on race from 25-100mph wont give much of an accurate account of the gears effects. At 25mph both should be in 1st gear. We don't know how fair the start is, if one gets a jump early or whatever, how well they're shifting, etc. The 12.5 car probably has a trap between 113-118mph while the 11.9 car can trap anywhere from 118-130mph. Shutting down at 100mph doesn't tell much to the capabilities of the car. I know you're not saying that the 3.90 gears negated it's 100rwhp advantage.....?
Old Nov 4, 2008 | 09:12 PM
  #63
jpee's Avatar
jpee
Your wrong no change needed.......
I disagree.... if the speedo is set for 2.73 and you change the rear end to 4.11 the speedo HAS to be reading wrong.. I HAD to use a Hypertek to adjust the speedometer in my 96 when I went from 3.08 to 3.73...
You HAVE to adjust the speedo if you change rear gears or overall tire height,, example from 26 to 28 tires..
Look at some of the on line calculators that tell you about adjusting if you change rear gear ratio...
Old Nov 4, 2008 | 09:23 PM
  #64
k0bun's Avatar
k0bun
The speed sensor is located in the rear so it calculates the rotations regardless of what gears are installed. No need to recalibrate.
Old Nov 4, 2008 | 10:11 PM
  #65
jpee's Avatar
jpee
We're going to have to agree to disagree.. unless someone who is more up in this than us.. I'm still saying if you change the rear gear ratio, you HAVE to re-calibrate the speedo..
Will someone who KNOWS FOR SURE PLEASE JUMP IN HERE
If need be I'll E mail a company that sells Ring & pinion gears, and ask if I switch from 2.73 to 4.11 will I have to re-calibrate my speedo, & I'll bet the house they say YES...
PLEASE SOMEONE WHO KNOWS FOR SURE JUMP IN!!!
Old Nov 4, 2008 | 10:27 PM
  #66
07 Z51's Avatar
07 Z51
I personally asked this question on two prior occasions - the answering party was, on one occasion, a former member of the Cartek staff whose name shall be supressed to protect the innocent (or guilty, who knows). The other time, it was Chris of ECS. I am going to go out on a limb here and suggest that these two people and entities know what they are doing.
Each time I was told the same thing - you need 270 electoral votes to become president. Sorry, I digress.
The answer is NO NEED to recalibrate. Why, I don't friggen recall but the answer is NO.
Now, where can I pick up the title to your house because you lose..........
Last edited by 07 Z51; Nov 4, 2008 at 10:31 PM. Reason: I am tired and can't type for $hit through blood shot eyes
Old Nov 4, 2008 | 10:58 PM
  #67
BOB EAGAN's Avatar
BOB EAGAN
Thank you. I thought thats what I stated.
Old Nov 4, 2008 | 11:17 PM
  #68
k0bun's Avatar
k0bun
Well don't bet your house just yet. What they tell you may not be correct for the C6. In our beloved C6, and the C5 I believe, the speed sensor is in the ring gear of the differential so when you change ring and pinion you are changing the signal to the speed sensor so your speedometer will read correctly. However smaller/larger size tires 1" or more will require a speedo recalibration.
Old Nov 4, 2008 | 11:27 PM
  #69
jpee's Avatar
jpee
If what you say is true, where did Chevy have the sensor on the 96's when I changed mine from 3.08 to 3.73 the speedo WAS WRONG, and I had to use a Hypertec program to correct it...Did Chevy change the location of the sensor from the C4 & C5 ?
Now I know this is apples & oranges but in my 87 Mustang, when I changed rears I had to change a small gear in the side of the transmission...
Old Nov 4, 2008 | 11:33 PM
  #70
BOB EAGAN's Avatar
BOB EAGAN
Like kobun stated in the C 6's and he believes the C5's ..........................The 96's are old technoligy and the mustang isn't a Corvette..
Old Nov 4, 2008 | 11:44 PM
  #71
BOB EAGAN's Avatar
BOB EAGAN
BTW I had 410's in my C6 and my top speed in first gear dropped from 60 mph to 50 mph at 7000 rpm. No speedo adjustment, so I know this is true. Hope this helps.
Old Nov 4, 2008 | 11:55 PM
  #72
jpee's Avatar
jpee
Well I've been wrong before, & it looks like I'm wrong again here... I'll take your word for it.... I gotta admit this is the first time I've ever heard of changing rear gears and not having to correct the speedo...
Old Nov 5, 2008 | 01:20 AM
  #73
Silver05GTO's Avatar
Silver05GTO
Here's my take after having 4.10's in the car for about 8 months. Should've put that money towards H/C.
Went to the track once with stock gears and once with 4.10's. The stock gear runs were ALL faster in ET, I lost 2mph in the 1/8 mile but gained it back and added 2-3mph by the end of the 1/4 mile. Launches were done on the stock runflats and ranged from 2.0-2.2's for both trips. I think I lost time in the quick 1st-2nd shift.
The car "feels" faster on the street but my limited time at the strip shows otherwise. Honestly there are times I want to revert back to 3.42's.
Haha, so if anyone out there wants to swap rears let me know!
Old Nov 5, 2008 | 02:11 AM
  #74
3 Z06ZR1's Avatar
3 Z06ZR1
Bingo
Old Nov 5, 2008 | 09:13 AM
  #75
xkilo16x's Avatar
xkilo16x
Out of curiosity, what did you run with the stock gears and with the 4.10s? Weather could've been a factor btw.
Old Nov 5, 2008 | 09:55 AM
  #76
k0bun's Avatar
k0bun
I couldn't tell you where it was located on your C4 or '87 Mustang. However I believe when they switched to a rear mounted tranny for the C5 they started locating the speed sensor in the rear. That has carried thru to the also rear mounted tranny C6.
Old Nov 5, 2008 | 02:48 PM
  #77
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Speedo Correction
If you have a Stick = NO CHANGE
If you have an Auto = CHANGE
You can check these items in HP tuners. There are different values for the auto trans vs manual trans. (I am too lazy look and post a copy of the HPT screen). If I recall correctly tire size (26.16) gear ratio (1) and VSS error are the same for both transmissions.
Once you change gears and/or the torque converter in a auto you have to change several values in the speedo pull down screen.
To Did I get slower?
Old Nov 5, 2008 | 03:46 PM
  #78
k0bun's Avatar
k0bun
Originally Posted by Tommy D
Speedo Correction
hmm interesting. This is the first I've heard it being different with an auto. Since I have a manual I'll take your word for it. Good info Tommy.
Old Nov 5, 2008 | 07:10 PM
  #79
Tommy D's Avatar
Tommy D
Hey Frank,
Thank you, Next time you see Dennis ask him how his speedo works I understand even with HP tuners the cruise control is still screwed up on the automatics (A4)
Old Nov 5, 2008 | 07:11 PM
  #80
k0bun's Avatar
k0bun
Hey Frank,
Will do. I'll probably see him next Thursday at the rental.
