barometric pressure
Old Nov 18, 2008 | 05:05 PM
  #101
JJC5's Avatar
JJC5
Wow..this thread really turned into a pissing match. Now I wish I wouldn't have said I was a pilot Although, that's probably the only reason that I know anything about b.p., d.a., r.h., dew point ect. But there is one more and that's pressure altitude!
I thought of something regarding density altitude and barometric pressure as it pertains to FI engines. If d.a. is high (less pressure, less dense), the supercharger or turbo will make up for that so therefore no h.p. loss. There is less aerodynamic drag in less dense air. Wouldn't that actually be beneficial in a drag race provided the FI is producing enough boost?
Old Nov 18, 2008 | 05:16 PM
  #102
dennis50nj's Avatar
dennis50nj
so are you saying the guys at higher elevation thinner air can cut threw the air faster less drag, while we at low elevation heavy dense air hard to drive threw
Old Nov 18, 2008 | 05:23 PM
  #103
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Actually that's incorrect. A better air day helps out F/I also.
Old Nov 18, 2008 | 05:25 PM
  #104
JJC5's Avatar
JJC5
Exactly. One reason that aircraft fly at the altitudes they do is because of the thinner air, therefore true airspeed is higher. Think of the extreme: If in a vacuum, as in above the atmosphere, there is no aerodynamic drag. Higher altitudes are closer to a vacuum than lower altitudes
Old Nov 18, 2008 | 05:26 PM
  #105
JJC5's Avatar
JJC5
Only if the there is no limitation on the amount of boost ie; waste gate. If the forced induction is set to a specific pounds of boost, it shouldn't make a difference. Humidity will though. But Hey, I'm NO tuner so I might be off base here.
Old Nov 18, 2008 | 05:43 PM
  #106
dennis50nj's Avatar
dennis50nj
so then these guys in arizona have been suckering us about we have such great air but they have the fast air at the high altitude so then they could get a +1000 da and we could have a+1000 da and they would be faster because of thinner air and less humidity,
Old Nov 18, 2008 | 05:51 PM
  #107
JJC5's Avatar
JJC5
You're joking, right?
You're saying at +1000 da at both places, and they would still be faster? Density altitude is density altitude.
Actually, re-reading your post, it's +1000 at each place so yes, that theory would be right because of their higher elevation to begin with. (I need to get back to work!!)
Old Nov 18, 2008 | 06:14 PM
  #108
07 Z51's Avatar
07 Z51
Doug from ECS correctly stated that the better air day helps FI as well. Someone correct me if I am wrong but I believe that the differential is less in FI than NA because FI creates, in a sense, its own atmosphere.
Old Nov 18, 2008 | 06:32 PM
  #109
JJC5's Avatar
JJC5
Originally Posted by 07 Z51
Doug from ECS correctly stated that the better air day helps FI as well. Someone correct me if I am wrong but I believe that the differential is less in FI than NA because [COLOR="Red"]FI creates[/COLOR, in a sense, its own atmosphere.
I agree with that. Instead of the intake manifold in a N/A engine having a slight vacuum (low pressure) at wide open throttle, the F/I unit, turbo or supercharger, can bring it to zero vacuum or usually positive pressure. So it is making its own atmosphere. If the supercharger makes 10 lbs of positive boost, my thinking is that it should make the same manifold pressure if the b.p. is 29.92 or 30.02. If the professional tuners say that the F/I engines like the better air though, I'll go with them and believe that.
Old Nov 18, 2008 | 06:33 PM
  #110
dennis50nj's Avatar
dennis50nj
yes it helps a better air day, but in a worse air fi its less noticeable, the bad air that is
Old Nov 18, 2008 | 06:37 PM
  #111
07 Z51's Avatar
07 Z51
Airpuss in Red, me in Black
Bull****, otherwise you wouldn't have opened your little mouth, but thanks for the thoughtful contribution
If you agreed with my DA explanation then you must agree that is not just 20 rwhp, figure 3% per 1000' DA power increase over worse DA, whatever that may be.
Again, your arrogance is assuming I agreed. I never said I agreed with your calculation. I thanked you for your explanation. I will now retract the thanks so as not to cause you further confusion.
Welcome to the club, and since you have a forced induction car you should also be aware that DA isn't near a major player because FI cars make their own atmosphere. Reread what I just said, I didn't say it didn't matter, but that the power differences between different DA's is not 3%, far less. I've owned a twin turbo LS2.
Had a forced induction car. As I said in a prior post (without reading yours first), I agreed that FI cars create their own atmosphere. Finally we agree on something.
I will if you'll stop crying, please. lol
Haven't cried yet Airpuss, just trying to point out that DA is not everything, something you have insinutated as being the sole reason for Dennis breaking into the 10's.
Actually I was tired of trying to read text that someone was too lazy to proofread and the run on sentences made little sense.
Next time, maybe I will abandon punctuation altogether. I did not realize that my paper was being graded.
And I'll return the favor, you're acting like an idiot that felt so self important he had to inject himself in this discussion.
Thanks for pointing out what I already acknowledged, Capt. Obvious.
I never said it was, but the oversensitive types, like yourself, like to read into it as some sort of personal attack then try and take what I said to the illogical extreme or totally take what I said out of context, including just making up what I said.
Funny, I never took it as a personal attack. I read what you wrote and chose to disagree. I took offense to you challenging the intelligence of others because you think that you are the all knowing pilot. Just because you fly near G-D does not mean you are G-D.
Because it's so difficult to drive an automatic transmission car? There are plenty of variables, never disputed that, but you cannot deny the effects of DA without looking like an idiot. But you're doing a good job.
Actually its a paddle shifted car. If it looks so easy to you, get yourself a ride in F-1. Let me know how that works out for you.
Dude, don't go away mad. Just go away.
Old Nov 18, 2008 | 06:38 PM
  #112
Ben Diss's Avatar
Ben Diss
Le Mans Master<br><img src="/forums/images/ranks/5k-6k.gif" border="0">
St. Jude Donor '08-'09
Yea, but somehow you figure out which track days will have a tail wind and you only go to (or publish figures from) those days. How do you do that? Oh wait, I know. You look at those fancy weather websites.
Old Nov 18, 2008 | 06:40 PM
  #113
Ben Diss's Avatar
Ben Diss
Naw, he should stay. This is fun. We should feel privileged to have our very own AirBusDriver to edumicate us.
Old Nov 18, 2008 | 06:42 PM
  #114
dennis50nj's Avatar
dennis50nj
but i never been at atco in a tall wind if i am you think propping the hatch up will help
Old Nov 18, 2008 | 07:33 PM
  #115
Ben Diss's Avatar
Ben Diss
I'd do it. Yea. Definitely, that'll help...
We should keep this going. We're 1:1 on views:posts. Talk about a private thread.
Old Nov 18, 2008 | 07:35 PM
  #116
Vito.A's Avatar
Vito.A
Default Density altitude (DA) does have a huge affect on engine performance
Density altitude (DA) does have a huge affect on engine performance. Look at the NHRA times in Denver vs Englishtown. Most dyno's are set up to automatically correct for standard day (that's usually how they fudge the numbers).
I have raced at Atco and Englishtown as well as Firebird Phoenix and SIR Tucson and there is a huge difference. We typically log DA of 0 to -1000' in NJ and Firebird is usually around 3000'. Tucson gets up to 7000' in the summer because the elevation is at 3000'MSL and the temps are over 100. Las Vegas and Boise are also high where as Pomona, Sonoma, and Seattle are great.
For the race cars we compute and log DA for every pass. We use a trailer mounted weather station with a pager that pages us the updated weather every 5 minutes.
Below is the NHRA altitude correction factor table. It adjusts for elevation only and does not account for temp. Also notice that supercharged and turbocharged adjustments are 1/2 that of the normally aspirated cars.
NHRA altitude correction factors
Below are the NHRA Altitude Correction formulas for all sportsman categories for NHRA member tracks that are classified as altitude facilities:
NHRA ALTITUDE CORRECTION FACTORS
Comp, S/C, S/G, S/ST
Convert to Sea Level Convert to Altitude
Track Name Alt ET MPH 1/2ET 1/2MPH ET MPH 1/2ET 1/2MPH
DIVISION 4
Amarillo, TX 3700 .9646 1.0337 .9823 1.0168 1.0367 .9674 1.0180 .9834
Roswell, NM 3700 .9646 1.0337 .9823 1.0168 1.0367 .9674 1.0180 .9834
DIVISION 5
Denver, CO 5800 .9405 1.0563 .9702 1.0281 1.0633 .9467 1.0307 .9726
Douglas, WY 4900 .9508 1.0466 .9754 1.0233 1.0517 .9555 1.0252 .9772
Grand Junction, CO 4800 .9520 1.0455 .9760 1.0228 1.0504 .9565 1.0246 .9777
Great Bend, KS 1900 .9853 1.0143 .9927 1.0072 1.0149 .9859 1.0074 .9929
Julesburg, CO 3500 .9669 1.0315 .9835 1.0158 1.0342 .9694 1.0168 .9845
Pierre, S.D. 1700 .9876 1.0122 .9938 1.0061 1.0126 .9880 1.0062 .9940
Pueblo, CO 4900 .9508 1.0466 .9754 1.0233 1.0517 .9555 1.0252 .9772
DIVISION 6
Acton, MT 3700 .9646 1.0337 .9823 1.0168 1.0367 .9674 1.0180 .9834
Anaconda, MT 5100 .9485 1.0488 .9743 1.0244 1.0543 .9535 1.0264 .9762
Ashcroft, CAN 1700 .9876 1.0122 .9938 1.0061 1.0126 .9880 1.0062 .9940
Boise, ID 2700 .9761 1.0229 .9881 1.0115 1.0245 .9776 1.0121 .9887
Lewistown, MT 4100 .9600 1.0380 .9800 1.0190 1.0416 .9634 1.0204 .9814
Medicine Hat, CAN 2400 .9796 1.0197 .9898 1.0098 1.0209 .9807 1.0103 .9903
Prince George, BC 2200 .9819 1.0175 .9909 1.0088 1.0185 .9828 1.0092 .9913
Saskatoon, CAN 1600 .9888 1.0111 .9944 1.0055 1.0114 .9890 1.0057 .9945
DIVISION 7
Albuquerque, NM 5400 .9451 1.0520 .9725 1.0260 1.0581 .9506 1.0282 .9747
Fallon, NV 4000 .9612 1.0369 .9806 1.0185 1.0404 .9644 1.0198 .9819
Inyokern, CA 2400 .9796 1.0197 .9898 1.0098 1.0209 .9807 1.0103 .9903
Las Vegas, NV 2100 .9830 1.0165 .9915 1.0082 1.0173 .9838 1.0086 .9918
Palmdale, CA 2700 .9761 1.0229 .9881 1.0115 1.0245 .9776 1.0121 .9887
Salt Lake, UT 4400 .9566 1.0412 .9783 1.0206 1.0454 .9604 1.0222 .9798
Tucson, AZ 3000 .9727 1.0262 .9863 1.0131 1.0281 .9745 1.0139 .9871
NOTE: Supercharged and/or turbocharged cars (i.e.: AA/A, AA/AT, BB/A, BB/AT, A/PM and AA/PM) use half factor; TA/D and TA/FC cars are not factored.
Old Nov 18, 2008 | 07:40 PM
  #117
walterm32's Avatar
walterm32
Thank You. Enough Said.
DIVISION 4
DIVISION 5
DIVISION 6
DIVISION 7
To barometric pressure
Old Nov 18, 2008 | 07:58 PM
  #118
Ben Diss's Avatar
Ben Diss
So, what you're saying is that Dennis wouldn't have a 10 sec bolt-on car if he ran it in Denver? Is that right? Really? Say it ain't so.
Let me ask you this. Are the DA's in NJ lower than the rest of the USA, on average? Is it true that running your car in NJ as opposed to the majority of states will result in faster times? If this is true, then we'll have found ONE good thing about NJ.
Old Nov 18, 2008 | 08:15 PM
  #119
walterm32's Avatar
walterm32
Regardless of when, where, and under what conditions Dennis ran a 10 sec pass, he did it. I don't think he'll be adding "But it was at ATCO with a negative DA" to his liscence plate frame any time soon.
Old Nov 18, 2008 | 08:29 PM
  #120
patton's Avatar
patton
St. Jude Donor '09
wow what a state slogan....Come to NJ and suck in this
