What is the Answer?
Old Nov 22, 2008 | 03:17 PM
Paulkr's Avatar
Paulkr
Default What is the Answer?
I will be getting my 05 mn6 back next week after installing a procharger,
along with the procharger I have 4:10 gears. Alot of forum members say the rear end is the week link so what can be done to avoid the breakage?
Old Nov 22, 2008 | 03:45 PM
BAADC6's Avatar
BAADC6
I have 4.10's...they were great but they are a little too much with my procharger. I have 604rwhp and have problems hooking up. I also installed a C5 rear housing with hardened shafts after I blew my first rear. I am now in the process of building something 750-8--rwhp and wiil be going with an RPM trans and possibly beefed up ZO6 rear. I am still researching options....but there are many ways to go. I would check out RPM and search the forums. The rear you have should be fine if you can avoid wheelhop.
Old Nov 22, 2008 | 04:44 PM
JT Metal's Avatar
JT Metal
St. Jude Donor '12-'13
Congrats on the blower.............Good advice above!!!
Old Nov 22, 2008 | 04:49 PM
saplumr's Avatar
saplumr
Spend your $$$$ "IF AND WHEN" you break it?? With street tires the chances are nothing will happen.
Old Nov 22, 2008 | 05:01 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
Most rears don't go on the street. If you plan on tracking it with DRs, be prepared.
Old Nov 22, 2008 | 08:06 PM
Paulkr's Avatar
Paulkr
ttt
Old Nov 22, 2008 | 10:41 PM
Walt White Coupe's Avatar
Walt White Coupe
Avoid wheel hop like the plague.
Old Nov 23, 2008 | 05:18 PM
Paulkr's Avatar
Paulkr
Thank you all for the replies! I hope you have a happy Thanksgiving
Old Nov 23, 2008 | 07:36 PM
keyplyr's Avatar
keyplyr
Originally Posted by Paulkr
...Alot of forum members say the rear end is the week link so what can be done to avoid the breakage?
I switched out mine (see mods.)
To What is the Answer?
