Surging issue please help!
Old Nov 28, 2008 | 11:10 AM
cody6.0's Avatar
cody6.0
Default Surging issue please help!
My car: 100% Stock 2007 C6 Z51 M6 with 4,000 miles
Lately I have noticed that my car surges when I hold a gear at low-mid RPM's. I also think this issue is causing the slight idle quality issues I thout were mis-fires a few months back also.
When driving normally at operating temperature if I hold third gear and keep at a steady MPH I can feel the car surge. While this hapens I can also see a small drop in RPM's on the tach. I have scanned the car and there are zero misfires while the surge is present.
It reminds me of when tried a K&N filter on my Cobalt SS Supercharged. But I am stock down to the paper filters on my C6.
Old Nov 28, 2008 | 11:33 AM
c6 batmobile's Avatar
c6 batmobile
If you had a misfire your check engine light would flash. You may have a loose sensor on your maf or a loose spark plug wire. I would start going over all your connections and try to find a loose one before you go and take it in thinking its a major problem. Had a surging problem with a rustang I used to own and it turned out to be a loose plug wire. Hope this helps.
Old Nov 28, 2008 | 02:45 PM
HANNY's Avatar
HANNY
you spoke to it being stock but have you done anything lately? like air filter change or anything under the hood for that matter?
A vacuum leak or intake tube leak can give you alot of issues so i would start there then keep it basic (plugs, coil, wire etc..) a "slight" missfire alot of times wont turn on the CEL but will show up on a scan. good luck, paul
Old Nov 28, 2008 | 03:26 PM
cody6.0's Avatar
cody6.0
The only thing I have done lately was drive it and change the oil. I haven't had time to do much else because I was buried with work.
And hanny I also used a Tech2 and drove around for a while and got Zero misfires.
Old Nov 28, 2008 | 03:28 PM
JRHAWK9's Avatar
JRHAWK9
try cleaning the MAF with MAF CLEANER
Old Nov 28, 2008 | 04:30 PM
cody6.0's Avatar
cody6.0
Thanks for all the fast responses guys!
To Surging issue please help!
