Clutch problems (HELP!)
Old Dec 1, 2008 | 12:59 AM
Terry59's Avatar
Terry59
Got an 05 C6, original owner and just had the clutched replaced after 75k miles.
MSI did the work, apparently my clutch while worn still had some decent life left.
However the torque tube front shaft bearing was scored and torque tube front shaft fingers were damaged.
They needed replacement along with a slinger and tube retainer ring.
I was experiencing all the problems your currently dealing with, they lessen as the bearing and vehicle warmed up.
Hope this helps.
BTW, with the new Z06 clutch, it has a noticeably smoother engagement that the original did when the car was new.
