who has access to TSBs?
2008 CHEVROLET CORVETTE TSB 4052 Details
Bulletin #: 4052
Sequence #: 10022794
Component Name: 103000 power train:automatic transmission
Make: Chevrolet
Model: Corvette
Year: 2008
Summary: 2-3 upshift slip or flare. *kb
2008 Chevrolet Corvette 103000 power train:automatic transmission Technical Service Bulletin
http://www-odi.nhtsa.dot.gov/tsbs/tsbsearch.cfm
Maybe one of the GM techs will jump-in and help.
Bulletin #: 4052
Make: Chevrolet
Model: Corvette
Year: 2008
Subject: Flare and Or Harsh 2-3 Shifts
Models: 2007-2009 Cadillac Escalade, Escalade ESV, Escalade EXT
2007-2009 Cadillac SRX, STS, XLR
2006-2009 Cadillac STS-V, XLR-V
2009 Chevrolet Avalanche, Tahoe
2008-2009 Chevrolet, Suburban
2006-2009 Chevrolet Corvette
2007-2009 Chevrolet Silverado
2007-2009 GMC Sierra
2007-2009 GMC Yukon Denali, Yukon XL Denali
2009 GMC Yukon
2008-2009 GMC Yukon XL
2008-2009 Hummer H2
2008-2009 Pontiac G8
Equipped with 6L80 (RPO MYC) or 6L90 (RPO MYD) Automatic Transmission
This PI was superseded to add to the DO NOT replace list. Please discard PIP4395B.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some customers may comment on a flare or harsh 2-3 shift.
Recommendation/Instructions:
This condition may be caused by leaking 1-2-3-4 and 3-5-R clutch fluid seal rings (230 in SI document 1698360). The following conditions are indications that the fluid seal rings may be leaking:
• Delayed/extended or delayed with harsh feel initial Park to Drive and/or Reverse to Drive shifts, that are more likely to occur when the transmission temperature is below approximately 40 degree C (104 degree F).
• Harsh or flaring 2-3 shifts that are more likely to occur when the transmission fluid temperature is in the approximately 0 degree C (32 degree F) to 40 degree C (104 degree F) temperature range, but can be present at any temperature.
• Harsh 2-3 shifts that are more likely to occur at less than 50% tp.
Vehicles built in the January through August, 2007 time frame are more likely to have leaking fluid seal rings
Important: When inspecting the 1-2-3-4 and 3-5-R clutch fluid seal rings (230) there probably will not be visible signs that the seal rings are damaged.
If any of the conditions above describe the flare/harsh 2-3 shift condition replace the 1-2-3-4 and 3-5-R clutch fluid seal rings (230).
DO NOT replace the valve body, TCM or fluid pump cover assembly.
Important Note: The 1-2-3-4 and 3-5-R clutch fluid seal rings (230) must be properly oriented when they are installed. Incorrect installation could lead to fluid leakage and shift concerns. Refer to SI document 2178811 for installation directions.
My 07 has had this condition since I bought it. I am reluctant to have the dealer take it apart to replace the seals. Anyone had this done? And with success?
thanks
joe
Bulletin #: 4052
Make: Chevrolet
Model: Corvette
Year: 2008
Quantity Part# Description
3 24238238 Ring 4.189
1 24224577 Seal 4.226
1 24236927 Seal Kit 4.005
3 88861045 Fluid
Below is the complete description of the TSB:
Condition/Concern:
This condition may be caused by leaking 1-2-3-4 and 3-5-R clutch fluid seal rings (230). The following conditions are indications that the fluid seal rings may be leaking:
If any of the conditions above describe the flare/harsh 2-3 shift condition replace the 1-2-3-4 and 3-5-R clutch fluid seal rings (230), DO NOT replace the valve body or TCM
my 07 has had these symtoms for a while, but as stated, once the trans temp goes past 104 degrees it works fine!!!
Now all I need is the trans manual, so I can do it.
