the fastest bolt/on c6
Old Dec 9, 2008 | 08:46 PM
  #81
dennis50nj's Avatar
dennis50nj
Originally Posted by PRE-Z06
I understand that the converter is multiplying torque on the launch, but I imagine it's locked (minimize slipping) once in third (1:1) which happens before you cross the 1/8 marker (assuming 3.73 and 26" tire) then from there to the traps is just sheer power accelerating you (~4700-6100 rpm)...just curious if you run any octane booster or meth injection?
nope plain sunoco 93. maybe i exsplained it wrong what i am trying to say is when i get a dyno my numbers are exstremly low because i dont get full converter lock in 3rd or 4th, my dyno with stock converter was 376 rwhp 375 rwtq after converter and pully ported fast 373 gears 375rwhp because the converter wont lock on the dyno so its not a real reading
Old Dec 9, 2008 | 08:53 PM
  #82
Tony B4's Avatar
Tony B4
St. Jude Donor '08
4th gear is 1 to 1, not 3rd gear.
Old Dec 9, 2008 | 09:18 PM
  #83
PRE-Z06's Avatar
PRE-Z06
4th in a m6, but 3rd in his case (a4)
Old Dec 9, 2008 | 09:44 PM
  #84
PRE-Z06's Avatar
PRE-Z06
a good comparison is jbs's full bolt-on ls3(pretty much the same as you minus the ewp I think) now his numbers may be a little on the high side and yours a little on the low side, but you gotta admit he's making more power than you w/ the xtra cubes and better heads...yet you out run him from the 660-1320 when y'all are both in 3.73 final drive (as he has the same rearend gears) no shifting taking place, just pure power propelling the car
Old Dec 9, 2008 | 10:05 PM
  #85
dennis50nj's Avatar
dennis50nj
no i don't believe the ls3 is making more power if it makes 30 more hp i have that covered with the ported fast, dyno numbers are just numbers 1/4 mile times are real as mph goes is what they say. two different builds different weights different rotating mass, tire selection changes his gears to mine and at what point i get into third for that slingshot effect, my momentum doesn't stop as with a manual thanks to my Cartek trans tuning, you cant compare JBs 660-1320 because he had a slower start now if he did the first 0-660 the same as me then i pulled the last 660 then i would assume there could be something fishy if all else was equal as to weight, but the 1.43 says it all that's why great 60 fts are necessary.
Old Dec 9, 2008 | 11:02 PM
  #86
LS1LT1's Avatar
LS1LT1
Good point, a stock internals LS3 has very little (if anything) over a stock internals LS2 with a properly ported (in this case, Cartek ported) FAST intake on top of it. Now when the FAST intake comes out for the L92/LS3 heads then that could alter the scenario a bit.
jbs's car is of course a manual versus Dennis's automatic so the rear wheel numbers will still read higher all else being equal but that's not necessarily relevant to this particular topic of conversation.
Sixty foot really is so critical, especially in an automatic car.
And it's not that Dennis's car is pulling so incredibly strong once it hits half track as much as the car is already charging from the start and just carries it. Just a properly, and very likely a perfectly geared/convertered/tuned combo.
I'm still betting that in a higher speed/highway race at the same place/on the same day that jbs's car would still pull on Dennis's car, maybe not kill it of course but it would beat it.
Old Dec 9, 2008 | 11:06 PM
  #87
dennis50nj's Avatar
dennis50nj
Old Dec 10, 2008 | 01:33 AM
  #88
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
Originally Posted by LSCHLEM
I thaught a while back you would come east for some better air. Ive heard the DA argument for some time. I commend you on the new record for Man transmittion bolton. But remember in spite of the
atmospherics out there " You have the torco advantage"
If I did not have a very busy route to run here in Ca, I would really think about a run back east...
We do start with 91, but ya gota love the Torco!!!
Old Dec 10, 2008 | 01:46 AM
  #89
jbsblownc5's Avatar
jbsblownc5
St. Jude Donor '08
And even though it's quite likely that you would ultimately run a new best (and possibly even hit the 10s), it's a pretty safe bet that you also wouldn't see his numbers out here either...it takes a lot more than just hopping into the car and making a quick pass or two to shave off nearly a full 7/10ths of ET, even for a stellar driver like yourself.
That colder air and 2000+ foot shift in DA comes with a whole new set of barriers and obstacles too, especially for a manual car.
I hear ya on your points, but I did grow up and go to college in upstate NY, so I'm familar with driving in the cold weather.
Thanks for the props on my driving...
Old Dec 10, 2008 | 01:47 AM
  #90
PRE-Z06's Avatar
PRE-Z06
that's what gets me also, you 60' faster yet you out mph him too...you even said yourself that a car that 60's harder usually mphs lower yet you get faster...he has roughly the same first gear as you also, but does have an xtra shift so that is gonna slow him no matter how quick he is...oh well, gary ran a 10.89 and 126mph w/ less cubes, w/o a fast, ewp or udp and worse aerodynamics to boot...it's gotta be the air! thing is I ran at atco and englishtown in the spring of last year, but my car wasn't tuned up there and was running lean so it didn't help...you sure the timer didn't stop at the 1000'? j/k, wish I still up there to see it in person
Old Dec 10, 2008 | 02:11 AM
  #91
jbsblownc5's Avatar
jbsblownc5
St. Jude Donor '08
Can't argue with most of this, two very different built cars, auto vs stick.
I will say that while MPH does say a bunch, it does not correct for DA.
Old Dec 10, 2008 | 02:21 AM
  #92
jbsblownc5's Avatar
jbsblownc5
St. Jude Donor '08
Gota love Atco on a good air day!!!
On a side note, I do want to say for the record, that I think Dennis's car is really optimized for a 1/4 mile run, and he and Cartek have gone the extra mile to be on the top of the list!!!
Old Dec 10, 2008 | 02:36 AM
  #93
oldmansan's Avatar
oldmansan
St. Jude Donor '09
I posted in another thread about two weeks ago that if anyone got close to Dennis' time he'd just step it up a notch. That was before his new best time. Dennis posted implying I was a good judge of character. Then he obliterated his old time. I think Dennis has a few tricks up his sleeve still.
jsblownc5, you're close and I'd love a ride in your car sometime. My car is stock and I'd love to experience some real power.
San
Old Dec 10, 2008 | 02:39 AM
  #94
jbsblownc5's Avatar
jbsblownc5
St. Jude Donor '08
San
I take both my cars out for hard drives on weekends whenever possible, I'd be happy to give you a ride!
Old Dec 10, 2008 | 03:00 AM
  #95
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Cool.
San
Old Dec 10, 2008 | 08:49 AM
  #96
dennis50nj's Avatar
dennis50nj
the car is a great 1/4 car and street car manners of course smooth idle its a bolt/on car, but we paid attention to the little details, is it great around town ? yes and on the turnpike parkway 295 and long fast rides, on a road course it would be al right with the stock tires, but JBs car is better for that, he wants a canyon runner and part time 1/4 car, i want a 1/4 car, he at the top of what he wants. im sure if he built it full time 1/4 i would have to step it up a notch because he is a great driver and charlie is tops
Old Dec 10, 2008 | 08:51 AM
  #97
dennis50nj's Avatar
dennis50nj
San
To the fastest bolt/on c6
Old Dec 10, 2008 | 09:10 AM
  #98
dennis50nj's Avatar
dennis50nj
yes usually it does mph lower if there is no spin, so if i spun a little it would have been better mph, but remember 3800 converters lose a little mph up top. and you saw Garys great time and mph, next time your up let us know and you can see it first hand, there were guys at the last two rentals that were vette docs and cow customers and seen it do it plus i told them check the car, i might just let you take it for a pass
Old Dec 10, 2008 | 09:35 AM
  #99
theofel's Avatar
theofel
St. Jude Donor '10-'13
Dennis's car is by far the fastest bolt on C6 in the quarter mile. Everyone seems so hung up on Dyno numbers. Dennis's car in not only a Bolt ON but its also a BOLT OFF! He is also a little old school. Hundreds of pounds lighter than most C6's. Just the way all of the world records were set. Divide his hp into the weight of his car...Now divide the weight of most C6's by their HP...Now you see why he runs so fast. His car is set up and tuned to the max in a very very light car..This is the winning combination that makes him #1 in bolt on's! He seems to be a perfectionist(pays attention to detail). He even let someone else drive his car that was 100 pounds lighter then him. Now that's the way to get a new record. Hats off to you... Dennis.
Old Dec 10, 2008 | 10:05 AM
  #100
dennis50nj's Avatar
dennis50nj
thanks Mike, i know my car is lighter then Joes. i dont know by how much unless we get on the same scale, have you weighed yours on the same scale
