lowest operating oil temp?
Old Dec 24, 2008 | 02:03 PM
terry s's Avatar
terry s
Originally Posted by Rock'n Blue 08
Strange
posts Unless you removed your t-stat! Because your oil temp is least 20 degrees higher than the coolant. On any Vettes I've been in show the
coolant at say 194 down the highway with the oil at 214. Your coolant
is temp going to be less than the oil!
The oil cooler on the C6Zs keeps the oil temp well below the coolant temp. What you said is right for cars without an oil cooler. I have never seen over 180 oil temp on my 08Z even in hot weather and the oil temp climbs slowly also. On my C5Z oil temps over 200 were common.
I thought about putting a cover over the oil cooler but that is no easy task to get to the cooler.
Old Dec 24, 2008 | 07:00 PM
Revving High's Avatar
Revving High
here in ****ty cold ugly NJ i keep it uder 2K rpm until it gets to operating temp. I let it idle for about 1 min before i drive.
