lowest operating oil temp?
Old Dec 16, 2008 | 11:06 AM
kumar75150's Avatar
kumar75150
Default lowest operating oil temp?
OK so I'm not used to all this cold weather we're getting down south right now.
Whats the basic protocol on warming up the car? I get in a wait til collant temp gets to at least 100 and usually 120+ before getting on my way.
Of course the oil temp doesnt start increasing until you actually drive the car a little, but is ~35 degrees fahrenheit or so okay?
total newb question i know but just curious
Old Dec 16, 2008 | 11:33 AM
Bill Suttie's Avatar
Bill Suttie
Your engine and the rest of your powertrain will warm up quicker on a cold morning under light load rather than letting the engine idle. Once you see your temp gage starts to move, drive like you normally do. This is how I did it during the New England winters many years ago.
Old Dec 16, 2008 | 11:43 AM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Do not accelerate hard or exceed 3000RPMs until the oil has reached 150F. The coolant will have reached its normal operating temperature by then.
No need to let the car sit idling for a long time; that does nothing to warm the rest of the drivetrain, wastes gas, and can foul your spark plugs and cause more carbon deposits to accumulate in the combustion chamber.
Old Dec 16, 2008 | 11:51 AM
kumar75150's Avatar
kumar75150
Thats usually what I do.
But I guess its ok to drive even if the oil is at 40F.
Old Dec 16, 2008 | 12:09 PM
mikeci's Avatar
mikeci
I usually take it easy till the coolant temp is at 160. the reason I say this is the tyres are still cold. if you haven't pushed a set of run-flats into a corner before they are up to temp believe me its a white knuckle experience. like watching a dog on a waxed kitchen floor.
Mike
Old Dec 16, 2008 | 12:12 PM
scottycards's Avatar
scottycards
St. Jude Donor '08 thru '13
Ok to drive with oil at 40*F- yes. I do it all the time here in Colorado.
Like Powerlabs says, under 3K, light load until you see at least 150*F oil temp. I wait till 160*, but probably no difference.
Mobil 1 is good stuff.
Old Dec 16, 2008 | 02:58 PM
PowerLabs's Avatar
PowerLabs
I wait untill 160F too. And I have driven away with the oil at 20F and on other cars I have driven when the oil is at 0F. When I know that will happen, I fill it up with Mobil 0W 40. No issues ever.
Old Dec 17, 2008 | 12:37 AM
kelp's Avatar
kelp
If you have a transparent catch can you will see the water is not driven off until 160*
Old Dec 17, 2008 | 07:12 AM
EuroRod's Avatar
EuroRod
Actually, any oil temp over 120 is acceptable, and any crankcase condensation will evaporate whenever the inside of the engine exceeds the outside ambient temp. It simply eveporates faster the higher the inside temp.
Old Dec 17, 2008 | 03:38 PM
3 Z06ZR1's Avatar
3 Z06ZR1
I like to see my oil temp make 200 like it's supposed to!
Old Dec 19, 2008 | 02:08 AM
HuskerBullet's Avatar
HuskerBullet
Ppppppfffffffttttt. I use AMSOIL, the best stuff. Once I start her up, 30 seconds later I'm gone, but I take easy until the oil reaches 100.....it's fine.
Old Dec 21, 2008 | 12:45 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
That's my personal rule of thumb as well. We get colder winters up here in the Puget Sound that I would've guessed before I moved here in 2005. I've gone through two winters now using the above listed approach on my 06 CTS-V daily driver using very short commutes (which are pretty hard on the oil's life) and my engine is still seeing very good wear numbers (see link below). I'm ready for my next oil change, but the outside temp is below freezing and it snowed 8" at my house last night... so doubt I'll get to it today.
Cadillac CTS-V Used Oil Analysis – Mobil 1 5w30 vs AMSOIL 0w30
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Dec 21, 2008 | 08:08 PM
JoesC5's Avatar
JoesC5
I have a 09 Z06, and with the oil cooler and ambient temps below 50*F it's hard to get the oil temp above 150*F, even after an hour of driving. 200*F is impossible in a Z06 unless it's summer and you're driving it pretty hard.
Old Dec 22, 2008 | 08:02 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
You could fashion a cover for the oil cooler for winter use. I'm thinking a naugahide lace up type of thing.
Old Dec 22, 2008 | 11:06 AM
C66 Racing's Avatar
C66 Racing
A lot of the C5 track crowd that put oil coolers on their cars had the same oil warmup problems and fashioned covers for them. Most of the covers I've seen were simple aluminum plates that slipped over the oil cooler, some simply held on with not much more than duct tape. Good luck making something.
Old Dec 22, 2008 | 11:23 AM
johnodrake's Avatar
johnodrake
Moderator
I haven't seen any specs on oil temp minimums for the C6. I use the limits for aircraft engines as a guide. The Lycoming IO-360 requires 75*F for run-up and 100*F for full power.
Old Dec 22, 2008 | 12:28 PM
Louis @ LG Motorsports's Avatar
0Louis @ LG Motorsports
Former Vendor
Kumar, My oil temp today was 136 after 30 minutes of driving. Coolant temp comes up to temp quick, but oil temp lags.
I try to get oil temp over 100, but in this weather, that becomes difficult to do quickly.
You might have to put some tape on the oil cooler
The Z51/C6 guys have it easy, the coolant will warm the oil
To lowest operating oil temp?
Old Dec 22, 2008 | 06:34 PM
NORTY's Avatar
NORTY
I can't get my oil temp >175F no matter what I do! I drove 100 miles yesterday and the temp was <135F! (Outside temp was 60F.)
Old Dec 22, 2008 | 08:16 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Strange
posts Unless you removed your t-stat! Because your oil temp is least 20 degrees higher than the coolant. On any Vettes I've been in show the
coolant at say 194 down the highway with the oil at 214. Your coolant
is temp going to be less than the oil!
Old Dec 23, 2008 | 11:20 AM
Former Vendor
Not on the new Zs atleast. My oil temp is NEVER higher than the water temp. Usually its 30-50* less, which I find odd.... The extra tank and better oil system might be the cause of that.
Now, my 08 LS3, yes, it was the other way around.
