Battery dead, keys inside...
Old Jan 3, 2009 | 06:06 PM
slaytera666's Avatar
slaytera666
St. Jude Donor '08
Default Battery dead, keys inside...
Just like the title says. I got back from vacation, one set of keys and fobs in the car, I lost the other set when I moved. WTF can I do? Anything? Call a locksmith?
Old Jan 3, 2009 | 06:09 PM
dennis50nj's Avatar
dennis50nj
you can get a lock smith to unlock the back then pull the cable for the door open hood charge, even if the battery wasnt dead you locked the keys in right
Old Jan 3, 2009 | 06:12 PM
dgman2's Avatar
dgman2
Your Fob has a built in key. Pull out the base of it.... key is attached.... open your trunk with that key. pull a latch on the Rt side of your trunk to open your door.... open your hood.... jump start your car or get a new battery if needed.
Good luck!!
Old Jan 3, 2009 | 06:38 PM
slaytera666
St. Jude Donor '08
Right, my only key and fob is inside.
Old Jan 3, 2009 | 06:47 PM
dennis50nj's Avatar
dennis50nj
you will be able to get a key made at the dealer with the vin number with id and proff of ownership, then you can open the hatch
Old Jan 3, 2009 | 07:47 PM
lockman's Avatar
lockman
the one question I have is WHY would you put the key inside the car ? other than that I don't which would be cheaper a locksmith or getting a key made. neither will be cheap.
Old Jan 3, 2009 | 07:55 PM
danl72's Avatar
danl72
Old Jan 3, 2009 | 08:25 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Were it me, I would call OnStar on my cell phone and have them unlock it remotely for me. But, that's just me.
Elmer
Old Jan 3, 2009 | 09:07 PM
johnodrake's Avatar
johnodrake
Moderator
Elmer
Elmer, OnStar don't work with a dead battery
Old Jan 3, 2009 | 09:17 PM
saplumr's Avatar
saplumr
If the fob is in the car with the doors locked....how do you know the battery is dead?
Old Jan 3, 2009 | 09:20 PM
dennis50nj's Avatar
dennis50nj
if he has onstar he can jack the front and hooh a charger to a ground block and the hot to the starter wire
Old Jan 3, 2009 | 09:39 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
That's what I would do No onstar for me though... I'm not paranoid, but the very thought of it makes me uncomfortable. I'd hook up power to the car after I jacked it up and then hope the fob was not in a dead zone.
Old Jan 3, 2009 | 10:06 PM
dennis50nj's Avatar
dennis50nj
if i leave the fob in the car its set to lock, so i dont
Old Jan 3, 2009 | 10:12 PM
johnodrake's Avatar
johnodrake
Moderator
The car isn't supposed to lock unless it 'sees' a fob leave the car.
Lockout Protection
Your vehicle can be programmed to sound the horn
three times and unlock the driver’s door when both
doors are closed and there is a keyless access
transmitter inside the vehicle. When the driver’s door
is opened, the key in reminder chime will sound
continuously. The vehicle will remain locked only when
at least one transmitter has been removed from the
vehicle and both doors are closed. See DIC Vehicle
Personalization on page 3-68.
Old Jan 3, 2009 | 10:15 PM
johnodrake's Avatar
johnodrake
Moderator
If the battery can be jumped, the fob in the car will open the door.
Old Jan 3, 2009 | 10:55 PM
dennis50nj's Avatar
dennis50nj
if i leave the fob in the car it gives a beep beep warning in which you have so many seconds to get the door open and get the fob out, i took the car to cartek and dave left the fob in by accident they usually put them on the cowell near the wiper, but he didnt it locked, i couldnt get there and they had to work on it so they had the dealer make a key, also at the last track rental i had JMT1669 try and recode one of my tire sensors well he left the keyfob in the car on acc shut door and got out, i was loked out at the rental with the car in acc mode draining the battery i had to go all the way home and get the other fob
Old Jan 4, 2009 | 01:09 AM
PowerLabs's Avatar
PowerLabs
Unless you lock the fob in the trunk... Ask me how I know
To Battery dead, keys inside...
Old Jan 4, 2009 | 01:13 AM
LS1LT1's Avatar
LS1LT1
Old Jan 4, 2009 | 01:29 AM
Victor'sVette's Avatar
Victor'sVette
I would jack the car up and charge it. If the fob is in the car (can you see it?), then it will open the doors.
I don't know what it is with the C6 corvettes and the batteries draining, but....I just happened to have a friend that did the same thing, left his in the car and the battery drained, tried to open the door, no light on the door lock. We charged it and the door opened. Keep in mind, that is only if the fob IS in the car.
Old Jan 4, 2009 | 04:10 AM
berserk_195's Avatar
berserk_195
i had the exact same problem!! and put up a thread...(fast solution jack car up recharge it from under the car took me 3 minutes)
here is my link:
http://forums.corvetteforum.com/c6-t...ever-done.html
