Help!!
Old Jan 4, 2009 | 01:43 PM
gunnerrun's Avatar
gunnerrun
Default Help!!
Is there a wheel sequence for bleeding brakes on the c6 and if so what is it?
Old Jan 4, 2009 | 03:12 PM
EuroRod's Avatar
EuroRod
R rear.
L rear.
R front.
L front.
Old Jan 4, 2009 | 05:43 PM
Wayne O's Avatar
Wayne O
CF Senior Member
Being there are separate brake circuits on modern cars it may not matter but I believe the service manual still specifies the sequence as:
RR
LF
LR
RF
Old Jan 4, 2009 | 06:50 PM
VET4LES's Avatar
VET4LES
RR
LF
LR
RF
My 2005 service manual page 5-53 spells it out.
Old Jan 4, 2009 | 07:53 PM
Swiftrider08's Avatar
Swiftrider08
Always is wheel farthest from the master cylinder first. Always the rear, then the opposite rear and then across to the opposite front and finish with the wheel closest to the master cylinder. This rule works on right hand drive vehicles also.
Old Jan 4, 2009 | 08:27 PM
TEXHAWK0's Avatar
TEXHAWK0
Not always true...brake circuits are not set up like they used to be on older cars.
The Right rear/Left front sequence is also correct for C5s.
Old Jan 4, 2009 | 08:54 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Here it is from Helms for the 2007 C6:
http://www.ls2.com/boggs/c6/Hydrauli...20Pressure.htm
RIGHT REAR
LEFT FRONT
LEFT REAR
RIGHT FRONT
Old Feb 8, 2009 | 09:28 AM
AO-08's Avatar
AO-08
Default diag set up?
Does anyone know if each part of the master controls diag corners of the cars brakes? My 1985 BMW was like this instead of front-rear set up.
To Help!!
