Brake Caliper Bolt Torque Specs
Old Jan 20, 2009 | 12:37 AM
cmonkey713's Avatar
cmonkey713
Default Brake Caliper Bolt Torque Specs
I will be replacing my brake pads this week and was needing the torque specs for Z-51 caliper bolts. Anyone have that handy? Thanks
Old Jan 20, 2009 | 07:29 AM
mikeci's Avatar
mikeci
brake caliper guide pin bolt (JL9, J55) 23 lb ft
disc brake pad pin (J56) 30 lb ft
all front & rear caliper bolt & bracket bolt (JL9. J55. J56) 129 lb ft
hope this helps
good luck
Mike
Old Jan 21, 2009 | 11:28 AM
Wayne O's Avatar
Wayne O
CF Senior Member
I believe the service manual recommends replacing the bracket bolts any time you remove/replace them (maybe they're like a torque-to-yield bolt). That said, an experienced C6 racer I know always removes the bracket bolts (to pull the caliper) when replacing his brake pads. He doesn't replace the bracket bolts and he's never had a problem...they're on extremely tight.
Old Jan 21, 2009 | 10:17 PM
cmonkey713's Avatar
cmonkey713
Thanks for the info!
Old Jan 22, 2009 | 01:18 PM
blown34's Avatar
blown34
I usually snug the bolts up, then apply one good grunt. In 50 years of wrenching have never had one come loose!!
Old Jan 22, 2009 | 10:40 PM
cmonkey713's Avatar
cmonkey713
I'll remember that.
To Brake Caliper Bolt Torque Specs
