End link question
Old Jan 27, 2009 | 07:12 AM
EuroRod's Avatar
EuroRod
Default End link question
I've been reading some posts about premature wear on sway bar end links. My car has developed a "knock" at the right rear when the car moves away from a dead stop and I was thinking this could be my problem. My question is: How can you determine that a link is bad? Thanx.
Old Jan 27, 2009 | 09:10 AM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
You could always pull the sway bar off, as long as you are not doing anything crazy.
Old Jan 27, 2009 | 09:21 AM
c607z51's Avatar
c607z51
i'm going through that right now but i was getting it in the front. the dealer replaced the end links on the front sway bars and car is still making a knock sound. i get 4 continuous knocks when making a left or right turn.
Old Jan 27, 2009 | 06:31 PM
Mike's LS3's Avatar
Mike's LS3
My dealer replaced the back two end links on m 08 coupe and it still makes a popping or knocking noise at low speeds over bumps, driveways and parking lots. I checked the end link bolts, shock mount bolts and there are tight, but the popping is still there.
Old Jan 27, 2009 | 06:41 PM
C6400hp's Avatar
C6400hp
Check the front end links, I had some clunking/ popping at parking lot speeds over undulating pavement that sounded like it was coming from the middle of the car and it was the front end links.
Old Jan 27, 2009 | 11:01 PM
RFP's Avatar
RFP
St. Jude Donor '09
Default Axle Nuts ?
Have you checked he rear axle nuts ?
See: http://forums.corvetteforum.com/search.php?do=process
Cheerz!
Old Jan 28, 2009 | 12:29 AM
HANNY's Avatar
HANNY
shock bolts that are a little loose, maybe the sway bar bushings or the end links are the most common. possibly a tie rod end as well, front and rear has tie rod ends. good luck paul
Old Jan 28, 2009 | 09:38 AM
Pylons's Avatar
Pylons
lay down under the back of the car and grab the sway bar at one end and shake it...see if you can feel slop or hear the same clunk...then try the other end
Old Jan 28, 2009 | 11:32 AM
HOXXOH's Avatar
HOXXOH
I'm now curious to know if these link problems ever show up on any unmodified base/F55 suspension.
I never heard noises on my F55 till I swapped to Z51 sways. Maybe the base bars were soft enough to absorb the shock and the stiffer ones transmit it to the frame.
Just a thought.
To End link question
