Replacing the front spring
Old Jan 28, 2009 | 12:29 PM
jrnorman's Avatar
jrnorman
Default Replacing the front spring
I have an '09 Coupel with a F44 option that now has Z-51 sway bars and that was a big improvement, but I also have a Z06 front spring (same as Z-51) that I want to try.
The '09 manual is not available and I have never worked on a Corvette before so I really do not want to take anything for granted.
It looks pretty simple, jack up the car, loosen the clamps to the frame and . . . then what happens?
Do the front Wheels need to be supported? How much spring tension will be released? Will the length of the clamp bolts be long enough to safely release any residual spring tension?
If I put it back to near the same ride height, it shouldn't affect the alignment much should it? Surely not enough that it wouldn't be safe to drive to get another alignment, huh?
Old Jan 28, 2009 | 01:39 PM
nwc6's Avatar
nwc6
I swapped Z06 springs onto my C5. Pretty much the same system. I had to disconnect the A-Arms on one side to slide the spring out. Doesn't matter which side. You will have to get both front wheels off the ground. The clamp bolts didn't have tension on them. Its a pretty easy job.
Mark the adjustments cams with a black marker and you will get very close on the reassembly. Your going to have to get an alignment anyway..
Old Jan 28, 2009 | 03:10 PM
jrnorman's Avatar
jrnorman
Default Thanks!
It really is as simple as it looks then! Amazing!
I had not thought though about needing to remove an A arm for clearance. I guess I would have figures it out eventually but it sure is better to know going into it.
How did your swap go for you? You get what you were looking for?
Old Jan 28, 2009 | 05:38 PM
nwc6's Avatar
nwc6
I had a base C5 suspension and sways. Converted to Z06 springs, shocks and sway bars, wheels and tires. It cornered like it was on rails.
When I bought the C6, I got the Z51 package and I really like it.
To Replacing the front spring
