Failed Timing Chain Pictures
Old Jan 30, 2009 | 11:26 AM
1.8t's Avatar
1.8t
Originally Posted by k0bun
This is a good point, if in fact the Z's chain is the same. Two of the more well documented cases, yours 1.8t and welcome2try, had variables other than just more power that may have contributed. I believe yours was a possible manufacturing defect in the chain itself, correct? Welcome2try's breakage was due to faulty/incorrect parts in the valvetrain from improper install. His was also and '05. I had heard that the '07? chain was slightly stronger. Can anyone confirm that? I don't believe an UD pulley is the cause however I feel it's more than just simply more power or else I think there would be a lot more stories like these. That being said it's silly not to upgrade the chain when doing a cam swap. Have there been occurances of the aftermarket chains breaking? If so does anyone know the cause in those cases?
My pin worked loose as well. That was the manufacturing defect that we cited as my failure.
Old Jan 30, 2009 | 12:09 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree that it appears to be a defective chain. Last I heard or saw, there are no master links on them just to insure they don't come apart.
Old Jan 30, 2009 | 12:27 PM
gath47's Avatar
gath47
I was also under the impression that there is no master link, but for some reason this link is a significantly darker color than the rest. This lead me to believe that it was a "master" link somehow. If not, then maybe the stress of bending changed the color or it was always a different color? Maybe it was a defective part?
Old Jan 30, 2009 | 02:24 PM
1.8t's Avatar
1.8t
There are no master links on these chains.
Old Jan 30, 2009 | 03:58 PM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
No master links!!
