Failed Timing Chain Pictures
From what I can tell it appears to be the stock chain. The section that failed has one darker link which makes me assume that it's the 'master' link. The link with the missing half of the pin has a stretched hole which leads me to believe that the pin either pulled through and then broke, or it broke, walked out and then got torqued.
The links at the failed pin are not as flared as other cases I've seen which leads me to believe the pin split before the chain came apart allowing the separation to occur with less pressure on the links.
The damper also appears to have slight markings, but they might be normal. On the side of the crank sprocket where the chain ended up piling up there is a wear mark. Either the broken chain made that mark after piling up there, or the pin walked out and started rubbing. Since it's only present on one side and doesn't appears to be scored multiple times I'm thinking that it was the chain piling up.
Based on everything else I've seen in the valvetrain my best guess is that the chain stretched, developed slap and failed. When I placed the chain on the gears it did seem loose, there certainly was room for it to impact the damper.
Please comment/speculate, but keep the arguing to a minimum!
I think the pin pulled through and then failed. Another member last month had a similar timing chain failure that I said the same thing about...it appeared the pin wasn't peened over enough to keep it in place and walked out of one side causing too much stress on the one remaining link. In his case, the link failed, not the pin. The really interesting thing is the bend you have in the link the pin is still in looks exactly like the bend in the link his pin was in on his chain. I'll see if I can find the thread, the member is "1.8t".
PS There is no master link. A master link is designed to come apart to enable removal of a chain that has to go around a frame for instance...like a bicycle or motorcycle. All of the links on your timing chain are peened over.
Edit: I found the thread. http://forums.corvetteforum.com/c6-t...-pictures.html
But will tell you this, as an ASE master technician i have never changed a broken chain on a small block chevy. Some stripped gears or maybe a loose chain but never just broken. My good friend who has worked as a master technician at a chevy dealership for the last 20 years has also never changed one out that was broken.
Take that for what its worth,,,rea lworld info with a combined 35 years of experience,, There may be a rare case out there of a failure on a stock engine but i have nvere heard of one. I am only posting this info for one reason, i could care less whether anyone agrees or not but to merely blame the chain and not look into other possible issues would be in my opinion a mistake you will regret. I am not looking to be a target to go after only trying to assist you in your issue and hope that it doesnt happen again. I dont think you will find even "one case" of a failed timing chain on this forum where the engine was stock. What could have cause this? look to the parts you put on aftermarket wise, heads springs, cam etc.. and go from there. Good luck on your issue and i wish you the best on fixing your ride, it stinks when they are down.
Unfortunately, some of us only "hear" what we want to hear.
Modifications have killed more engines, transmissions, rearends, and outright cars in here, than than DDT has killed cockroaches.
Power is the thing that kills a chain and its why the LS2 breaks them and LS1's dont. The average power is up with so few people running stronger chains. I laugh when people talk about resonances with UD pullies. They are the same pullies with the same cranks as the LS1.
Now, have something bind and you'll break it or the gears.
And the harmonics are diffferent for the LS1,2,3. There is not a known answer currently or those who do actually know are not saying.
