Which Sway Bars?
Old Feb 6, 2009 | 08:07 PM
mikeci's Avatar
mikeci
Originally Posted by oldmansan
Replacing the shocks would be my suggestion. It seems to be the consensus for all models of the C6 (base, Z51, Z06) except for the F55 fans.
San
adding a tunnel plate and poly bushings also will complete the job
Old Feb 6, 2009 | 08:08 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
I haven't done the tunnel plate, but does it really make a big difference? Thanks in advance.
San
Old Feb 6, 2009 | 08:41 PM
BlackMoon's Avatar
BlackMoon
San
What's a good brand?
Old Feb 6, 2009 | 09:15 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
The Konis and Bilsteins seem to be the choice of many for fairly low $.
San
Old Feb 6, 2009 | 10:15 PM
mikeci's Avatar
mikeci
I went w/ the Pfadts there the most expensive but the nice thing is they are adjustable w/o even jacking up the car so is you like to track the car on the weekends it a quick change system just reach in and turn the ****.
Mike
Old Feb 7, 2009 | 12:21 AM
BlownStealth's Avatar
BlownStealth
Originally Posted by ejbarre
Part #s
10323434 Front Z51 Sway Bar
10339124 Rear Z51 Sway Bar
10387838 (2) Front Insulators
15241135 (2) Rear Insulators.
How much should this be$$$
How much better does cornering improve on stock c6 auto
Old Feb 7, 2009 | 07:08 PM
biggums's Avatar
biggums
I was told that the Pfadts bushings on some cars can pop and make large noises. A major forum seller tech talked me into Z51 sways and stock bushings.
Old Feb 7, 2009 | 09:05 PM
miami08VETTE's Avatar
miami08VETTE
If you want to do shocks, I can vouch for the Koni FSD's. They function as advertised.
Old Feb 8, 2009 | 07:57 AM
mikeci's Avatar
mikeci
the pfadt bushings must be greased properly when you install them then they won't make any noise. and they make a dig difference over the stock bushings.
Old Feb 8, 2009 | 10:10 AM
BlackMoon's Avatar
BlackMoon
Does anyone know what comes on the Z06?
Old Feb 8, 2009 | 10:53 AM
CraigE's Avatar
CraigE
My Pfadt Bushings have been in for 1.5 years (12,000 mi) with no noise or other problems. I did grease them with the supplied grease per the instructions.
The poly bushings really enhance the Z51 sways, and they are only $30.
The suspension feels much tighter.
I highly recommend them.
