Which Sway Bars?
Old Feb 3, 2009 | 02:28 PM
vette#2/707's Avatar
vette#2/707
Cruising
Default Which Sway Bars?
Hey guys I have two quick questions about sway bars? I have a stock
C6 with non- Z51 suspension. I was wondering which would give me better handling the Z06 sway bars or the Hotchkins sway bars.
How difficult are they to install?
Old Feb 3, 2009 | 03:56 PM
rovers2000's Avatar
rovers2000
the sway bars are easy to install, they would take about 1 hour with common shop tools and a way to lift the car. It is easier if you remove the tires. I am not sure about the Hotchkins bars but the z06 bars are great.
Old Feb 3, 2009 | 05:53 PM
Silverton's Avatar
Silverton
Go with the Z51 bars (the Z06 bars will induce oversteer), or, even better, get the Pfadt Street adjustable bars (their Pfatty competition bars are way too stiff). I've got my Phadt Street bars set on their middle position F/R. A huge improvement over the Z51 bars.
Old Feb 3, 2009 | 05:57 PM
miami08VETTE's Avatar
miami08VETTE
I have used Hotchkis on my last 2 cars and now on my 08 coupe. They are a quality product that delivers perfomance without costing an arm and a leg. For the vette they are adjustable but only at the rear. Can't go wrong with Hotchkis, especially for a street setup.
Old Feb 3, 2009 | 06:49 PM
HuskerBullet's Avatar
HuskerBullet
If you are never going to upgrade your tires/wheels to something wider later on, then stick with the Z51's. I also have a base C6 and I replaced the stock ones with the Z06's. It's true, there is oversteer if you are not used to driving this technological beast. However, I plan on major HP upgrades and wide tires later, so I didn't care....I kind of take it easy on turns until the other upgrades come in.
Old Feb 3, 2009 | 08:12 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Z51 bars work well.
Old Feb 3, 2009 | 08:15 PM
mikeci's Avatar
mikeci
best bang for the buck, z51 bars and pfadt ploy bushings they are cheap enough as a starting point if you want to go weekend tracking later its no big deal to upgrade to something better you didn't waste a lot of money on them and you can always resell them to some one like you who is just starting out.
Old Feb 3, 2009 | 08:56 PM
CraigE's Avatar
CraigE
And if you want a little more install the Koni FSDs.
Old Feb 3, 2009 | 09:46 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
I'm almost leaning towards the Hotchkis as they are adjustable. I have Hotchkis on my other car and I have no complaints.
San
Old Feb 3, 2009 | 11:42 PM
HANNY's Avatar
HANNY
z51's and the yare really easy to install. about a 5 on a 1-10
Old Feb 4, 2009 | 08:22 AM
Bob-New_Jersey's Avatar
Bob-New_Jersey
On a base C6 suspension, would the Bilstein Heavy Duty or Sport work better when upgrading to the Z51 front and rear sway bars. The Konis look interesting, but the cost is higher and from what I have been reading, it lowers the car.
Old Feb 4, 2009 | 12:34 PM
mikeci's Avatar
mikeci
I'm no expert but I can tell you this, sway bars do not do the same job as shocks. to put it simply sway bars limit the pitch or side to side roll of the car and shocks dampen the car over bumps the shocks also stop the car from going down the street like a pogo stick and No shock lowers the car no matter what make it is.
Old Feb 4, 2009 | 02:59 PM
lilpuu1's Avatar
lilpuu1
Does anyone know the PArt number for the Z51 front sway bar? I need to order one.
Old Feb 4, 2009 | 06:19 PM
ejbarre's Avatar
ejbarre
Part #s
10323434 Front Z51 Sway Bar
10339124 Rear Z51 Sway Bar
10387838 (2) Front Insulators
15241135 (2) Rear Insulators.
Old Feb 4, 2009 | 08:53 PM
TCKT B8's Avatar
TCKT B8
St. Jude Donor '09 & '11
I went with the Z51 sway bars and Koni FSD shocks on my 05 base coupe and am very pleased with the results. Still has a nice ride but corners flatter and stays down well on rough pavement.
Old Feb 6, 2009 | 02:29 PM
arik49er's Avatar
arik49er
I would vote for the Hotchkis sway bars. I know one of my buddies put them on his vette and said they were an improvement over his z-51 sway bars. He got his at www.thelapd.com
Old Feb 6, 2009 | 03:53 PM
danl72's Avatar
danl72
To Which Sway Bars?
Old Feb 6, 2009 | 05:53 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
I'm thinking about using the Hotchkis sways because of the ability to adjust the stiffness (in the rear) and the light weight. The Z51 sways are probably great, but the ability to compensate for a larger, more aggressive rear tire is worth the extra money to me. This is especially true if you are running a fairly normal sized rear tire on the street and have a larger/stickier rear tire on the track. The front Hotchkis are 20% stiffer than the Z51 and the rear are 15% or 45% or 80% stiffer depending on the setting.
San
Old Feb 6, 2009 | 06:08 PM
BlackMoon's Avatar
BlackMoon
Any suggestions on improving a Z06 suspension?
Old Feb 6, 2009 | 06:29 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Replacing the shocks would be my suggestion. It seems to be the consensus for all models of the C6 (base, Z51, Z06) except for the F55 fans.
San
