Valve Seating?
Old Feb 27, 2009 | 09:15 PM
gath47's Avatar
gath47
Default Valve Seating?
After putting my heads back together after replacing bent valves, I am just finding out that I may have to take the head to a machine shop to get the valves seated/lapped? Is this true?
The intake valves are the identical part, the exhaust valves are the same size, but may not be the identical part. Is there any case when seating at a machine shop would not be necessary?
I feel quite frustrated that I did not even hear of this in all of the research I've done over the past months. Even searches now on the forum do not return any information regarding this....
Old Feb 27, 2009 | 09:20 PM
midyearvette's Avatar
midyearvette
anytime you have bent valves the seats should be inspected also as they too could be damaged, also the guides and piston surfaces...sop......
Old Feb 27, 2009 | 09:44 PM
patton's Avatar
patton
St. Jude Donor '09
yes they need to go to a machine shop
Old Feb 27, 2009 | 10:10 PM
gath47's Avatar
gath47
Ugh, so a machine shop is going to be required... Some have suggested that I would be able to do the lapping myself on the cheap, but with prior bent valves it seems that there are other things that will need to be checked...
Anyone have any idea what this could end up costing?
Old Feb 28, 2009 | 09:46 AM
oneblackvette's Avatar
oneblackvette
Quick test would be for you to get some lapping compound and try to do yourself. If you find a lot of uneven lapping marks, you have no choice but to have the heads worked on. Price could be all over the place if seats or guides need work.
Old Feb 28, 2009 | 10:06 AM
midyearvette
machine shop is mandatory here...good luck
Old Feb 28, 2009 | 12:57 PM
c6 batmobile's Avatar
c6 batmobile
My guess would be a few hundred bucks. Every thing that holds the valve needs to be inspected to make sure it didnt warp out of tolerance. Youre better off leaving this job to a professional.
Old Mar 1, 2009 | 10:38 AM
glass slipper's Avatar
glass slipper
From your recent thread:
http://forums.corvetteforum.com/c6-t...-pictures.html
Go to the last post...
Look at the bright side, at least you haven't put them on yet.
Old Mar 6, 2009 | 03:48 AM
gath47's Avatar
gath47
Hmm, I may not have revisited that thread after your post. Wish I had.
Searching on the forum is somewhat hit or miss. Should have searched for lap vs lapping? Thanks for the help anyhow.
To Valve Seating?
