Steering rack front end noise
Old Mar 1, 2009 | 11:07 PM
FIREMANMIKE's Avatar
FIREMANMIKE
Default Steering rack front end noise
I've noticed lately when i trun the steering wheel I hear a poping noise that sosnd like uts frim the rack, It almost sounds like its binding. Anyone experirnce this??? Any TSB's for something like this??? I also get this really weird kind of thing going on,maybe related maybe not. When going slowly (parking lot, making U turn, etc...) it feels like the tires flat...or like the wheels buckling under. Maybe its normal with a run flats, which are new to me, but its kind of discerting. Anyone have any ideas???
Old Mar 2, 2009 | 07:31 PM
FIREMANMIKE
Nobodys had any steering rack issues???
Old Mar 2, 2009 | 08:59 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
It could be a number of different issues.
1st The rear diff could be binding up and causing a slow speed headache. This is kinda of common. There is a update with GM on this.
2nd tie rod end, wheel bearing, bushing, a simple front end wobble from your hands will tell you the story.
3rd it could be your rack and has issues. These are harder to detect.
4th The pump could be going out, and at low rpm bad pumps don't produce a even pressure to the rack
5th Crankshaft dampener, they do slip and they do weird things.
Randy
Old Mar 3, 2009 | 06:26 PM
jimc62k7's Avatar
jimc62k7
There is a power steering hose TSB out there...sorry don't have the id handy.
Old Mar 3, 2009 | 07:12 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
I just had the power steering hose TSB done to my wifes car. It is for Z51 cars only. The symptoms are different though. If I was sitting in say, a parking lot, car in drive, not moving, and turn the steering wheel back and forth, it would make a loud groaning noise. It was like it didn't have enough steering pressure or the tires had too much grip. If it was in neutral/park it didn't do it. If it was on a slick surface, like the garage floor, or a wet surface, it didn't do it. The hose did fix the issue though.
Old Mar 3, 2009 | 07:40 PM
NYC6's Avatar
NYC6
Most likely the wide front tires grabbing and sticking on cold pavement. Happens to alot of us when pavement and tires are cold and turning sharply at slow speeds. Been discussed many times here over the years. Do a search. Dont be alarmed it will go away when it warms up.
Old Mar 5, 2009 | 01:23 PM
ajohnson007's Avatar
ajohnson007
Default I had my steering rack replaced.
I was getting the same sounds. GM said a seal failed and lost all the fluid. Car was good until a week or so ago now I am getting clunking sounds from under the car gm can't find anything wrong. I have not had a chance to check it out yet. Any ideas?
Old Mar 5, 2009 | 02:30 PM
drag-on's Avatar
drag-on
Default Noise from steering
Just got my car back from the dealer yesterday for this and they found the sway bar links were "faulty" whatever that means. They replaced them and the noise is gone.
To Steering rack front end noise
