i am looking and alot of people say ngk or innovate...i read the article on wideband comparison in a controlled environment and the ngk came in last place and the innovate came in first...some say b/c it was a comparison done by innovate...
The article you refer to was apparently a very poorly done test (from a scientific perspective). I.e. the consensus is that that particular article should be ignored.
Regarding the upgraded sensor, the vendor I spoke with (when buying mine) said that to be honest, although the upgraded sensor was technically more accurate the difference between the two was not significant enough for your average user.
Innovate LC-1 is all I use. Pair with a DB gauge or XD-16 gauge(a bit overkill). The thing with Innovate is they need a good power source, which is where alot of people dont install it right. They tap any old 12v source and if its not clean, the sensor doesnt like it. I haven't installed one in a vette yet so I cant tell you exactly where to tap into it. It also uses replacement bosch sensors from any autoparts store.
thanks for the input...i may just do the ngk...i'll probably spring for the better sensor b/c it will bug me down the road if i didn't get even though i may not need it...i am weird like that...haha
I use the PLX Devices WBO2 and works great. It is much simpler and easier to use than the LC-1, which I had. The D.A Converters in the LC-1 are very sensitive and had mine replaced twice.
