Hydrolocked LS3
Old Mar 18, 2009 | 12:10 PM
QuikZilver's Avatar
QuikZilver
Default Hydrolocked LS3
Puddle was a little too deep for my 08. Was about 6 inches deep, but the puddle won. Motor cut right off...wouldn't start up. I took the air intake hose off and a good amount of water poured out of the TB. Called my insurance company to have it towed to my local performance shop and to place a claim. Warranty won't cover, due to Callaway Honker intake. Not even going to try. Not a great way to start off the day.
Those that have hydrolocked an LS motor, what type of damage is generally done? Thanks.
Old Mar 18, 2009 | 12:25 PM
Mike's LS3's Avatar
Mike's LS3
Originally Posted by QuikZilver
Puddle was a little too deep for my 08. Was about 6 inches deep, but the puddle won. Motor cut right off...wouldn't start up. I took the air intake hose off and a good amount of water poured out of the TB. Called my insurance company to have it towed to my local performance shop and to place a claim. Warranty won't cover, due to Callaway Honker intake. Not even going to try...unless my insurance doesn't cover, then I guess I'll buy a new shroud and have the shop put it back to factory and pay for towing to the dealer. Not a great way to start off the day.
Sorry to hear about your hydrolock issue. I hope the damage is minimum. However, your loss will make many think twice about aftermarket air intake mods. I reverted back to the stock LS3 intake, it's actually a well designed intake. Good luck and I hope you are back in your vette soon.
Old Mar 18, 2009 | 12:26 PM
CODE4LS1's Avatar
CODE4LS1
Well, water will not compress, so more than likely some cracked ring lands and bent rods. The damage could be more than that depending on engine speed, etc..
Old Mar 18, 2009 | 12:38 PM
wazslow's Avatar
wazslow
Water def wont compress, but I would still pull the plugs and try cranking it and see if you can pump some water out of it. Ive hydrolocked my racecar with fuel before and didnt hurt anything.
Old Mar 18, 2009 | 12:44 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
So your plan is to return it to stock before returning it to the dealer?
For what purpose? Why not just take it to the dealer as is?
Old Mar 18, 2009 | 12:45 PM
PAUZAO's Avatar
PAUZAO
Well, I guess this is a first report of a hydrolocked motor with a Callaway Honker.
Old Mar 18, 2009 | 12:46 PM
PAUZAO's Avatar
PAUZAO
...Because they would most likely not cover it under warranty...
Old Mar 18, 2009 | 12:49 PM
JayplaySS2's Avatar
JayplaySS2
This same thing happened to me years ago when I had my 5.7 Iroc. Ran though a huge puddle and BOOM. Total lock. Wouldn't even crank over, just bang, bang when you turned it over, the starter couldn't budge it. I sat all night, pulled 3 plugs and there was very little water. After about 35-40 tries, it started to turn over. 5 or 6 more and it started, next day, ran perfect.
Did the same thing to my wife's Mazdaspeed6 huge, puddle, starting smoking and boom. Shut right off. Next day, I took off the MAF and cai tube, dried it out, ran perfect.
Water never got to the rings on the Mazda, but on the Iroc, it was near death but I got lucky.
I have seen guys pull the plugs, spray pentrating oil in overnight and have it turn over and start the next day. Or, your shortblock is toast. Good luck though, serriously.
Old Mar 18, 2009 | 12:53 PM
'06 Quicksilver Z06
No, there was at least one other.
The thread was complete with pics of the hole in the engine block, and was deleted shortly after it was posted up.
Warranty is not going to cover it anyway.
His insurance company might possibly cover it. But I certainly would not alter or tamper with the car at all, ie attempt to take it back to stock, before contacting them and filing an insurance claim.
Insurance fraud is serious business.
Old Mar 18, 2009 | 01:10 PM
LS1LT1's Avatar
LS1LT1
No, actually it's not.
Not to come off like a preaching, goody two shoes or anything but this is not the time to be passing off driver error/mistakes onto GM's warranty system.
Old Mar 18, 2009 | 01:20 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Insurance will cover it under you comprehensive policy... you warranty doesn't cover hydrolock even when 100% OEM stock.
How fast were you going when you hit this puddle? I've driven Corvettes going on 10 years now w/ CAIs on all of them. When it's raining hard you slow down. If you see a deep puddle, turn around!
Even w/ the stock intake you can flood the car.
Old Mar 18, 2009 | 01:34 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I hydrolocked my VW Scirrocco motor many years ago in an overflowing creek. Plugged the plugs, blew it all out, dried the plugs and she fired up. Steamed a whole lot but ran.
Old Mar 18, 2009 | 01:57 PM
wazslow's Avatar
wazslow
Before you go crazy with insurance/warranty stuff. Pull all the plugs and try cranking it...
Old Mar 18, 2009 | 02:55 PM
QuikZilver's Avatar
QuikZilver
I just had it towed over to the performance shop. They are going to take a look at it. When it locked, it would not start back up at all..starter isn't doing anything. I understand about the warranty issue as stated above. My first post, I was a little frustrated, but it will not be at a GM dealership for warranty work. I will have the shop repair the damage. I was at a very low speed (at most 10mph) and tried coasting through the puddle...ie foot off of gas, engine at idle. But, that didn't help. I'd say there was a good 1/4 cup of water that poured out of the throttle body, when I removed the air intake tube. As for CAI's, I have run them on other Corvettes (C4 and C5) I have owned and other cars and this is the first time I have ever had something like this happen. I'll keep you all posted as to the damage they find, if they find any.
Old Mar 18, 2009 | 03:10 PM
Cobra4B's Avatar
Cobra4B
^ Sorry to hear... must have been a large puddle.
Old Mar 18, 2009 | 03:21 PM
04_Z06_CE's Avatar
04_Z06_CE
sux to hear about your issues...
I would for sure make it completely stock and I mean if you cut your shroud buy a new one and take it back over there , you got nothing to lose that this point ...its your money , maybe they take the bait...
BTW this is why I dont do Honker , varaam etc.. Just too risky...IMO
Nevermind just realized you took it to your perf shop already , either way GOOD LUCK MAN!
Old Mar 18, 2009 | 03:47 PM
LS1LT1's Avatar
LS1LT1
Excellent advice.
100%
To Hydrolocked LS3
Old Mar 18, 2009 | 04:03 PM
knkali's Avatar
knkali
I have gone through some puddles that were 6 inches with my Honker but luckily no probs. Were you moving pretty fast?
Old Mar 18, 2009 | 04:33 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I believe it was just 3-4 days ago that Callaway rep posted that there's never been a claim made, nor any correspondence to them re hydrolocking. It's too bad it happened.
Old Mar 18, 2009 | 07:40 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Just because the starter isn't doing anything dsoesn't mean you did severe engine damage. The starter would have been under water too and probably got wet enough to short out. I would dry out the starter and pull the plugs and turn it over. You may be just fine.
As to trying to play footsie with the dealer, I am a prude also and don't believe it's to your or anybody's interest to attempt fraud.
