headers and issues
Old Mar 21, 2009 | 08:20 PM
Paulkr's Avatar
Paulkr
Default headers and issues
Has anyone experienced leaks from lg headers and the X-pipe pulling away from the collector?
Old Mar 21, 2009 | 08:42 PM
c6 batmobile's Avatar
c6 batmobile
Ive heard they have leak problems. Dont personally have them though. Just word of mouth from others.
Old Mar 21, 2009 | 10:03 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Yes do a search! Problem is a slip joint collector. Kook's, ARH use a compression type
that can't fail.
Old Mar 21, 2009 | 10:13 PM
PAUZAO's Avatar
PAUZAO
Yes, when I had mine they leaked as well.
Old Mar 21, 2009 | 10:15 PM
Modshack's Avatar
Modshack
not with the clamps tightened!....
Old Mar 22, 2009 | 02:15 AM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
my only gripe with the lgs is removal, slip connectors are a galactic pitas to take apart and reinstall
Old Mar 22, 2009 | 12:18 PM
Paulkr's Avatar
Paulkr
I have went as far as replacing the clamps to keep the X-pipe to the header collector, still did not work!! as far as the leaks they are in the tubes and the welds around the collector,
Old Mar 22, 2009 | 02:36 PM
JRLedFoot's Avatar
JRLedFoot
One option is to have your exhaust shop spot weld the pipe joints with a Mig welder in addition to the clamps.As for leaks,the Mig can also be used to seal,but it's permanent! You may not want that.Slip type clamps don't always do a good job but they supposedly(Please correct me if I'm wrong) make it easier to disconnect/remove the pipes because they don't crimp the metal like the compression type or commonly known as U-clamps.Also,because the slip type don't crimp the pipe,they don't distort pipe ID,ensuring maximum exhaust flow with minimum restriction or back pressure.It's a compromise in the name of performance, also,APITA!
Sorry for the long winded response,I worked exhaust for a few years.
Regards,
JR
Old Mar 22, 2009 | 07:05 PM
Paulkr's Avatar
Paulkr
I can understand at the collector due to the poor design , but have people experienced cracks in the tubes also, and what would the "PROPER FIX" be
To headers and issues
