Motor HP verses RWHP
LS2; Dynojet 248 SAE corrected = Manual 340-345 RWHP
" '' '' '' '' '' '' '' '' '' '' " '' '' '' '' '' '' '' = Auto 330-335RWHP
55-60 HP loss manual and
65-70 HP loss automatic.
Same should hold true for the LS3 since it's pretty much the same drivetrain. Worked for my LS3, it dyno'd 373RWHP for an A6 w/NPP
436 Advertized
373 Dyno
63 HP loss to the rear wheels from advertized.
I have not done any recent comparisons but on a previous car I did a number of comparisons on different dynos with only one being a electricity generating dyno. The Dynajets were all over the map; probably +/-10% variation with the same setups but the dyno with generators was the lowest of all. The owner of the shop warned me that if I was looking for something to brag with then this was not the dyno to rent. He specialized in track cars only by the way.
Anyway my point is that the drive train and auxiliary losses are probably higher than what you might think from the typical dyno numbers.
Trying to use a 1500 RPM/60 MPH part throttle cruise situation to discredit the use of a constant during a full throttle 6000 RPM/150 MPH dyno run is comparing apples to oranges. I'm not saying the use of a constant is absolutely correct, but it'll get you a lot closer than a percentage unless all a person is interested in is inflated HP numbers. In that case, we should all just use 25%.
So for a given rpm, it is fairly constant? If so, is there a relevant range of HP that would apply (e.g. 400 RWHP +/- 20%) before we would want to update the constant say if we add a S/C or bigger cubes?
My way of reasoning about the problem is this. We know that the primary source of power loss through the drivetrain is kinetic friction. So, the question reduces to the replationship between the force of kinetic friction versus the force working against it. Is this force constant or not?
---Matthew Hicks
Actually, it might surprise you to know that kinetic friction is not the primary source of HP loss through the drivetrain on a chassis dyno.
A low RPM/low throttle scenario does not show a constant HP loss through the drivetrain is incorrect...there is a big difference in the oil windage losses in the transmission/rearend between 150 MPH and 60 MPH. There are inertia losses involved in accelerating to 150 MPH on a chassis dyno while there is zero inertia loss going a steady state 60 MPH down the road. That's the apples to oranges comparison I'm talking about. There are many, many, many things you aren't considering.
436 Advertized
373 Dyno
The ridiculousness of that notion manifests itself when you apply it to very high HP car.
Lets say we take a bone stock LS2 making 340WHP factory SAE certified crank HP is 400). I.E. 60HP or 15% loss.
Now we twin turbo the car and it makes 800WHP. How much does it make at the crank?
860HP, or 920HP?
If you believe it makes 920HP, you have to explain to me how that transmission is dissipating 90Kilowatts of heat every second and not causing the gear oil to vaporise
In reality the fixed number is not correct either because with more torque on the drivetrain losses do go up, but it is a lot closer to reality than multiplying WHP by a fixed amount. The only time the fixed number method becomes really innacurate is if you move the RPM at which peak power is made significantly; since losses will go up exponentially with speed, making peak power at, say 6500RPM will incurr a lot higher drivetrain losses than making it at 5500RPM...
860HP, or 920HP?
But while the drum is being accelerated, the crankshaft, conn rods, pistons, camshaft, clutch, driveshaft, transmission gears and shafts, differential gears and shafts, rear hubs, brake rotors, rear wheels and rear tires are ALSO being accelerated. This uncounted acceleration of the pieces AHEAD of the tire contact patch account for the biggest part of the difference between flywheel HP (at constant speed, by the way) and RWHP measured on an inertia dyno.
My very stock 2006 C6 MN6 dynoed at 340 RWHP, or exactly 85% of its rated flywheel HP.
When I increase the HP with cam, heads, FAST, Kooks, etc. the car will be able to spin that dyno drum up faster, and thus measure a higher RWHP. However, the crankshaft, conn rods, pistons, camshaft, clutch, driveshaft, transmission gears and shafts, differential gears and shafts, rear hubs, brake rotors, rear wheels and rear tires are ALSO spinning up faster, requiring more of the new larger flywheel power to do so. Thus, for my case, I would still GUESSTIMATE the flywheel HP at 117.6% ( 1 over 0.85 x 100% ) of the new RWHP.
With 3.90 gears, the innards (except for the brakes wheels and tires) are spinning up 14% faster than with 3.42 gears, so I intend to perturbate the % factor by 14%, i.e. RWHP will be 83% of flywheel power for a manual C6 with 3.90 gears.
Glass Slipper and PowerLabs - your comments would be most welcome.
