What next...
Your initial stab of the throttle is a little spin each time but you cant tell. After the clutch the stab will be much sharper and felt in the neck.
Regardless of what makes the power, the gears are very important for low end on both set-ups, NA and FI.
I have H/C, gears, nitrous, and an ECS kit at 12psi. With my mickey thompsons, this car's 0-60 is insane. I run them 24/7 as my tire on the street.
Gears are easy to measure. Whats faster, starting in second gear or first gear? Regardless of your power, gears make it all get going that much faster. Plan on them for any power level, NA or FI.
I should have been more specific:
It has NEVER slipped on the dyno. My car has been dynoed over 10 times now. Its lit the tires up on the dyno twice, but the clutch never slipped
I agree it will slip if I launch the car with sticky tires, but on the street tires, its the tires that go first...
My particular setup (since you asked specifically about it) is as follows:
2006 Z-51 MN6
Bone Stock LS2 engine
It made 395whp / 387wtq with a VaraRam, Kooks 1 3/4" Headers, GHL Exhaust and a tune.
I took the VaraRam out and installed an A&A Supercharger kit with the Vortech V2 Si-Trim Head Unit and a 3.8" pulley. This is their standard kit with the larger, lower boost pulley.
I also removed the GHL Exhaust and put C6 Z06 exhaust instead (inconsequential, but I did that because the GHL droned), and I had my intake manifold and throttle body ported (not much of a difference).
The Supercharger + Header combo running on pump gas was good for 597RWHP / 518RWTQ. I installed it with 36000 miles on the engine (the DAY my warranty expired
), and I'm at 45000 now. ZERO issues, no other mods except for non factory tires and stainless steel brake lines on my car.It is not the best, the baddest or the fastest on the forum. But I paid exactly $5300 shipped for the blower, and I make about 30horsepower more at the wheels than the new ZR-1, on a car I can still drive back and forth to work every day... It makes me happy. Hell I still laugh out loud after a good wide open throttle pull
2006 Z-51 MN6
thanks for the detailed response.. congrats on your numbers and I will be doing the same thing then.. thanks
