i know it is really not an either or situation but i have this thing about my motor being "opened" up.. i like to stick with bolt ons for reliability and driveability. (and cost) can you swap roller rockers on the new
LS3's and allow the the duration of the stock cam to do more?? has anyone done this yet??
I did this on my LS2, added SLP's 1.85 rockers. IMO, the gains don't justify the cost. I felt the same as you but was let down by their performance. Now with the FAST intake, I had nice low to mid range torque but overall, a mild cam would be better IMO.
with everything stock you will not really feel the difference in a roller rocker only change and as bunk22 stated for the cost it is not worth it. To do the change it is recommended that you change out your valvetrain along with the roller rockers which makes the cost go up and if you do that you might as well change out your camshaft.
I was like you and luckily I contacted bunk22 and he gave it to me straight and saved me a lot of money. I did go with the cam change and I did add Yella Terra 1.8 roller rockers, which I am totally satisfied with.
If you want to more power then I would suggest going with a ported SPIN FAST intake manifold and a ported throttle body, just the improved throttle response will put a huge grin on your face.
i know you guys are right. the real way to go is add the cam.. i guess i am just going to have to get over the fear of someone "opening" my engine. it just seems everytime i get something done the car just is not put back 100% right the first time. now i have to decide gx1 or gx3.... parts and labor are the same.. it is all about power and driveability..
I went with the Yellow Terra 1.7 rockers with my cam set-up. I will say, be careful with the cam selection as well. I went with a relatively med-large cam which gave great top end but lost low end. No big changes in the middle. Bumping the compression ratio and gears would be good for a big cam. Small to medium cam, probably not.
yeah i would not mess with the heads or compression. i already have 3.90 gears so i think i can get away with a so called stage 2 or mid range cam.. something that will still have plenty of torque at 3,000 rpm and up my hp approx 40-50 at rear wheels.
I wouldn't ignore your first thoughts on this. Your fear of "going in to your engine" is a valid concern. Since you didn't list your existing mods, it's really hard to address this one honestly. If you've already exhausted all the "basic bolt-on" mods, then maybe. But if you haven't, there's no way I'd be changing cam or rockers yet, ESPECIALLY since you have some concerns.
i guess i should list my mods in the future to help get proper or more informed advise. to date i simply have a CAI, LT headers, Tune and 3.90 gears. with a 6 spd manual.i am making 425hp and 420tq to the rear wheels.. i am very pleased with the power and can run with a stock Z06. my goal is to add approximately 50 more rwhp so i can run with a stage 1 Z06.. so i guess i am of the opinion it would be very hard to get 50 more hp without opening the engine.. any ideas???
boy thats AMAZING your making about 60HP more than anybody else with those same mods!
i think i am making the same hp that everyone else seems to be making with the LS3's.. I started with 384hp and 369tq. the mods added 40hp and 50tq to the wheels... giving me 424.somthing on hp and 419.something on tq.. but with the 3.90 it sure feels like a lot
it is the next 50 hp that is going to be tough or at least expensive...
Avatar says he's a member since 4/09, so I assume he has a ls3 with those numbers. Mods a worth 40 hp which would put him at 380 stock. That sounds right to me, what do you think?
Your numbers are par. The 390's definitely wake it up. Feels like an extra 30 hp. I have a h/c ls2 with 390's at 450/405, what a blast to drive. Have fun.
i am considering the following;
a very mild cam. the so called "hot cam" from gm supposed to add 50hp (which i seriously doubt) or a cam from LG motorsports. their gx1 (mild) or their gx2 (mid range). i want to add power everywhere!! peak numbers are useless. i want to add hp and tq from 2500 rpm thru 6500 rpm.. and my goal is 50 hp and 40tq..
It's a tough choice. Rocker Arms are pretty stealth, and give you 10-20 HP with minimal hassle. Problem is, it costs almost as much if not more than a cam. The other factor is how much a cam effects drivability. I have always thought a Vette seems weird sitting there loping away with a cam.
