LS7 cam on an LS3 engine?
Old Apr 15, 2009 | 03:17 AM
admoreno's Avatar
admoreno
Default LS7 cam on an LS3 engine?
has anyone done this? i bought a new Ls7 cam for 200 bucks. but i was wondering if itll make a big difference if i put it in my LS3.? if anyones has done this i would love the help as far as power increase
thanks
Old Apr 15, 2009 | 03:57 AM
EdwardETraylorIII's Avatar
EdwardETraylorIII
admoreno,
No, you wont see a "big difference" with an LS7 cam (the OEM LS7 cam is VERY mild). You need to have a custom cam ground for your mods - or call a vendor like LG who makes the GX53....
Folks usually do a cam and header/tune package and see NICE gains.
Old Apr 15, 2009 | 04:17 AM
TTRotary's Avatar
TTRotary
Lift on that cam is no good for LS2/3. These engines have 1.7 rockers, the Z06 has 1.8 rockers, so the LS7 cam would produce anemic valve lift on a LS2/3 engine. Besides which, the duration is pretty tame and the LSA is super conservative. Better off with a LS2/3 specific cam like Comp's 224/228 114 .582 / .588 XER grind.
Old Apr 15, 2009 | 06:23 AM
MarkRx's Avatar
MarkRx
dont forget to upgrade the rockers, and other valve train components. Do it right and not the cheap way like some of these shops. I see more and more places on this forum that advertise bang for the buck, you're motor will go BANG allright...
Old Apr 15, 2009 | 07:15 AM
SpinMonster's Avatar
SpinMonster
While aftermarket rockers are great if you want them, the number of rediculous powered daily drivers running around with the stock rockers without a failure is way too high to say they will go 'bang'. In fact the number of stock rockers that failed is pretty insignificant. Dumping the needle bearings isnt something I have seen posted in the C6 section at all.
Hardened pushrods and dual springs are pretty much the norm.
Are you aware of even a single car that failed due to rockers? Maybe you have seen some I didnt?
Old Apr 15, 2009 | 10:07 AM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
The only rocker issues I have seen was the loss of the needle bearings. For a minor fee, Harland Sharp will upgrade the stock rockers to eliminate that issue. There were several owners in the F-body Club in VA (lived there for 6 years) that were using stock rockers in excess of 600rwhp. No failures that I was aware of. Great quality dual springs and pushrods are a must if replacing the cam.
Old Apr 15, 2009 | 10:37 AM
vettl83's Avatar
vettl83
The only stock rocker arm failure I am aware of is some 07 and some early 08 Z06's having issues loosing the needle bearings.
Old Apr 15, 2009 | 01:04 PM
admoreno's Avatar
admoreno
Originally Posted by EdwardETraylorIII
admoreno,
thanks alot... so am i better off trying to sell this cam?? cause if i go aftermarket like the LG one that means i have to get a whole kit so i wont have problems in the long run BANG!! sorta speak
Old Apr 15, 2009 | 03:02 PM
EdwardETraylorIII
admoreno,
Yes, ditch the LS7 cam.
Going with ANY cam (that will net you gains) will require this "kit" you speak of.
A kit is exactly what Spinmonster mentions.. A $200 set of valve springs, hardened pushrods (under $200) and the cam itself (usually around $440).
Investing in after market rockers is a waste of money. However, having the needle bearing mod done by Harland Sharp is a wise investment.
By the way, I run the OEM rockers (with the bearing mod from Harland Sharp - I've got a pretty high dollar build and didn't want to take ANY chances). They are a fine piece - take a look at my RWHP numbers if you think you need aftermarket rockers......
Old Apr 15, 2009 | 10:10 PM
Cunningham Motorsports's Avatar
0Cunningham Motorsports
Former Vendor
give us a call we have a variety of camshaft grinds that can take care of your needs, they all cost $390 shipped to anywhere in the lower 48 states, we can also get you hooked up with a complete kit with Pushrods, valves springs and camshaft.
Old Apr 15, 2009 | 11:08 PM
PRE-Z06's Avatar
PRE-Z06
I remember a guy who swapped one in an ls2 and gained ~20hp...I wouldn't say the lift of the ls7 cam is anemic, as it's almost .560" even w/ 1.7 rockers (211/230 on a 119.5 lsa), but any aftermarket cam out there will make more power
Old Apr 16, 2009 | 12:46 AM
kelp's Avatar
kelp
Oh too bad. I would have sold you mine for $160.
To LS7 cam on an LS3 engine?
