Connectors in door
Old Apr 17, 2009 | 02:21 AM
fulingbusen's Avatar
fulingbusen
Default Connectors in door
I am trying to connect a new door on my -06 Corvette. I am unable to find the connector in the middle (2-wire) of the picture below, does anyone know what this is for?
By the way, where should i post my project? Is there a section of the forum especially for project cars?
Old Apr 18, 2009 | 03:01 PM
fulingbusen
Am I in the wrong part of the forum?
Old Apr 18, 2009 | 03:16 PM
BEZ06's Avatar
BEZ06
I think you're in a good part of the forum for posting about your project - either here in the Tech section, or the General section. If it's a race/track car, you could post in the Autox/Roadrace section.
As far as the connector - I dunno!
You say you have a 2006, but what year did the door come from???
Does your car have XM??? In the 2006 and newer cars, the XM antenna is in the side mirror. If you got a door off a 2005 C6, the XM antenna was on the roof (halo) and you won't find an XM connector in the door if it's from a 2005. Or, if the door came off a car that didn't have XM then that connector probably won't be there.
Also, if your car has side airbags, the impact sensor is in the door back near the door handle. If you got a door off of a car that doesn't have side airbags, then there won't be a connector for the side airbag.
If your car has the memory buttons and the door you got came from a lower trim level car that didn't have the memory feature, that door would probably be missing a connector for that wiring.
Bob
Old Apr 18, 2009 | 06:07 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
That yellow female connector is for the antenna wire for the XM radio. It goes up to the outside mirror.
Tom
Old Apr 19, 2009 | 12:11 PM
fulingbusen
Thanks a bunch!
Is there an antenna in both mirrors?
I´ll post a project thread in the general section.
Old Apr 19, 2009 | 04:34 PM
RPHCRMZ51's Avatar
RPHCRMZ51
yes in both mirrors. I saw a post recently about this.
Old Apr 19, 2009 | 04:38 PM
BEZ06's Avatar
BEZ06
Originally Posted by fulingbusen
Thanks a bunch!
Yes.
Info in the Service Manual indicates that the antenna in the passenger mirror is for receiving the satellite signal, and the one in the driver's side is for receiving the signal from a terrestrial signal repeater.
I'll be watching for it!!
Bob
Old Apr 20, 2009 | 05:51 AM
fulingbusen
Doh! I have bought a mirror without the antenna in the driver side mirror...
Does this mean that the regular FM radio will not have an antenna then?
Old Apr 20, 2009 | 10:58 AM
BEZ06's Avatar
BEZ06
No problem with FM - the AM and FM antennas are in the rear fascia.
Bob
Old Apr 20, 2009 | 10:28 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Bob
My '07 has side airbags but they are in the seats themselves...not in the door. Why would a connector for them be in the door if I may ask?
Old Apr 20, 2009 | 10:39 PM
jvinsepa's Avatar
jvinsepa
to sense an impact and tell the bags in the seat to fire.
Old Apr 21, 2009 | 12:35 AM
dgrant3830's Avatar
dgrant3830
Ok, that makes perfect sense to me now...Thanks
To Connectors in door
