Shaving weight
Old Apr 22, 2009 | 04:14 PM
lyonsac4242's Avatar
lyonsac4242
Default Shaving weight
I know there is another thread about shaving weight out there, but for what it's worth, I got these weights when I replaced my battery and driver's side seat. 2005 3LT Z51 6sp manual
OEM Battery 36 pounds
Braille No weight battery 15.8 pounds
Saved 20.2 pounds
Stock seat (with airbag and heat) 51.8 pounds
Bride Low Max seat with Pfadt bracket and sparco sliders 26 pounds Saved 25.8 pounds
Total Saved weight is 46 pounds
Old Apr 22, 2009 | 04:17 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
What battery did you use exactly, and what did you have to do to get it to mount on your C6??
Good info
Old Apr 22, 2009 | 04:32 PM
lyonsac4242
Default www.braillebatteries.com
I went with the cheaper, non-carbon fiber model. It is the Spec B2015 No Weight battery. The 1st one I installed went dead after sitting for 5 days, but braille was great about getting a new one shipped out and this one has been fine. It is not for winter use and can't be left hooked up over the winter as it will drain. But as long as you drive your car a few times a week it is a great and easy way to save weight. It is more expensive than a standard replacement, but losing weight costs money. I used a generic battery mounting kit from autozone with 2 j-hooks, a rubber belt (flexible,but kinda stiff), and 2 wing nuts. This battery is a lot smaller than stock so I used my saw-zaw (spelling?) to cut off about 3 inches of the J-hooks, put 2 new bend in in, I drilled 2 holes in the battery holding tray (it's plastic), passed the j-hooks through the holes and tightened the battery down. Holds it in there very well.
Old Apr 22, 2009 | 04:53 PM
BornSUPERCHARGED's Avatar
BornSUPERCHARGED
If you take out the passenger seat you'll save another 26 pounds
Old Apr 22, 2009 | 05:52 PM
lyonsac4242
Default true
That's the plan, but wanted to make sure of the fit and function before buying 2 seats/brackets/etc... Ingress/egress is a lot more difficult, but it feels like I am in a race car now. Gotta have my wife's rear test fitted for passenger side. Probably just going to go with a little wider fit and less aggressive side boolstering... Looks cool now
Old Apr 22, 2009 | 06:46 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
That's the same battery I'm looking at, the B2015.
San
To Shaving weight
