Torque Wrench Question
Old Apr 24, 2009 | 01:48 PM
Shooter01's Avatar
Shooter01
Default Torque Wrench Question
When I go to Sears to buy a torque wrench any recommendations for basic work on a C6?
What range of torque is best overall for a C6?
Do I need a special socket for the lug nuts that won't marr the finish?
Thanks in advance!
Old Apr 24, 2009 | 01:51 PM
Louis @ LG Motorsports's Avatar
0Louis @ LG Motorsports
Former Vendor
Typically, you will need something 1/2" drive and up to 120ft/lbs. I would also get a 3/8 drive that will go to 75ft/lbs as well for internal engine work.
As for marring the finish, we get the correct socket, and put electrical tape on the outside. Never a marred up wheel
Old Apr 24, 2009 | 02:01 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
I've got two; a smaller one for things like spark plugs, header bolts, suspension stuff, and a bigger one for brake calipers and lugnuts..
Old Apr 24, 2009 | 02:55 PM
nwc6's Avatar
nwc6
I use these two for working on the corvette:
http://www.tooltopia.com/index.asp?P...D&ProdID=37826
http://www.tooltopia.com/index.asp?P...D&ProdID=11565
For the wheel lugs I use my old beam style torque wrench and I bought these for my wheel lugs:http://www.tooltopia.com/index.asp?P...OD&ProdID=8027
Old Apr 24, 2009 | 07:04 PM
Red86Cfour's Avatar
Red86Cfour
Why do you use a beam style torque wrench for wheels? The two TRs you link to ratchet in both directions. Generally, precision torque wrenches/tools don't, and they really shouldn't, be used in the opposite/loosening direction, only tightening.
Old Apr 24, 2009 | 07:30 PM
nwc6's Avatar
nwc6
Because the beam wrench is about 8" longer, more leverage and the 100ft/lb is at the max of my middle wrench, where my beam wrench goes to 150. I only use the others for actual torquing of bolts.
Old Apr 24, 2009 | 07:56 PM
haljensen's Avatar
haljensen
To do basic work correctly you need three torque wrenches;
1/4" drive for inch pound
3/8" drive for low foot pound up to 115
1/2" drive for high foot pound above 100
Old Apr 24, 2009 | 09:53 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
just a thought: take a lug nut with you to sears to buy the right socket. I forget which one was supposed to fit (19mm?), but the 3/4" deep socket was a much better fit.
Old Apr 24, 2009 | 11:11 PM
Shooter01's Avatar
Shooter01
Thanks you guys, appreciate your input! I just got my car three weeks ago and I'm looking at more support equipment I need and this site is helping a lot! I've got a floor jack, stands, detailing products, etc. yet to go, not to mention the accessories Take Care!
To Torque Wrench Question
