Nice writeup. I have just one comment, which is that the cubby fiberglas is not unsupported - there is actually a large stamped steel L- bracket that is welded to the frame and runs halfway across the cubby. More than strong enough for the battery.
I have a question though: on my 05, the pass. cubby has a bump in it that made it impossible to get the battery in there, so i had to use the left cubby (dropped right in). Is this not the case on 06 and newer (I am assuming the cubby was redesigned for the Z06)? Thanks.
Thanks guys,
Unfortunately the L bracket doesn't run 1/2 way beneath the cubby. It only supports about 3 inches of it. In order to get it to truly support those 3 inches, it could be modified a little because of the small gap between the bracket & the cubby. I glued a thin piece of plastic in between them. It's better then nothing.
I will take some pics this week & post them
Fits great. The D34 has lots of power. Just figuring out a tie down is a bit tight. I used a universal "I" shaped top bracket with 2, 1/4" rods & ran them thru the cubby floor & bolted them from beneath.
