Will a 2002 ZO6 DIFF WORK IN A 2005 C6
Old May 9, 2009 | 12:33 AM
Norman Lane's Avatar
Norman Lane
Default Will a 2002 ZO6 DIFF WORK IN A 2005 C6
Can someone out there let me know if it is possible to swap the diff out of my 2005 with the diff from a 2002 ZO6, because everything been hearing is how weak the diff housing is on the 2005 vette, any input will be great.
Old May 9, 2009 | 02:00 AM
tjwong's Avatar
tjwong
Nope, the cases between the two generations are totally different. The C5 case has a single rear mount, the C6 has two mounts, one on each side.
Old May 9, 2009 | 11:56 AM
c6 batmobile's Avatar
c6 batmobile
I will say yes. Im pretty sure there is a mod you can do to make it fit. I know for a fact spin has a c5 diff in his 2005 c6. You may want to contact him and ask him about the details.
Old May 9, 2009 | 01:32 PM
Sparo2's Avatar
Sparo2
I've heard of many guys doing this swap but don't really have any facts to back it. I know it's been talked about here in the forum.
Let us know what you find out.
Old May 9, 2009 | 04:25 PM
LS1LT1's Avatar
LS1LT1
Cartek Performance Engineering had been doing that very conversion since late 2004, feel free to contact them as well at 908-317-4496.
www.cartek.net
Old May 10, 2009 | 12:51 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
www.cartek.net
Yep. Just installed a c5 rear in my 2005 c6. Cartek makes a bracket to mount the rear and they send you a plate that you need to weld to your rear cradle.
Old May 10, 2009 | 07:22 AM
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
And it will be much stronger than you current 2005 rear. If you're going to do the swap, be sure to install a hardened shaft as well.
To Will a 2002 ZO6 DIFF WORK IN A 2005 C6
