Lightweight Battery Install (Pics)
Old May 12, 2009 | 02:15 PM
LS3FORME's Avatar
LS3FORME
I ran the odyssey in my lotus elise got a trickle charger and never had a problem if you do not use the car for more than a week put the trickle on it for a few hours, you do use a different one that a stock battery charger.
Old Jun 10, 2009 | 11:49 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Just an update. I've left the car sit for more than a week and it still cranks over just fine with the Deka battery. So far so good.
San
Old Jun 11, 2009 | 09:30 AM
PCMusicGuy's Avatar
PCMusicGuy
San
Let us know if it's the same after 6 weeks of letting it sit.
Old Jun 11, 2009 | 09:33 AM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
I don't that will ever happen. I live in California where I can drive all year long. The only reason it sat for a week is because I took a trip to the East Coast.
San
Old Jun 11, 2009 | 12:19 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Old Jun 12, 2009 | 12:57 AM
StoplightWarrior's Avatar
StoplightWarrior
that's awesome. I love threads like this. $82 and some creativity and you knocked nearly 17lbs off your front end. Awesome.
Old Jun 12, 2009 | 01:15 AM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
The Braille would have cost twice as much for the same battery.
San
Old Dec 31, 2009 | 10:40 PM
MP35N's Avatar
MP35N
Default Longevity
Hi, how's that DEKA battery holding up?
Old Jan 1, 2010 | 04:30 AM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Just fine. It sat for four weeks in the Southern California "cold" weather (really, it has been cold lately) and it started right up. Honestly, if you drive the car at least once every two to three weeks you'll notice the difference. I had a forum member pm me last week to see how the battery was before he purchased one. A great way to save ~17 pounds of weight.
San
Old Jan 1, 2010 | 10:00 AM
///DarkSide\\\'s Avatar
///DarkSide\\\
St. Jude Donor '12 thru '26
San
That was I
My Deka ETX18L is on its way from the same seller mentioned in the OP, $74 shipped. The Odyssey SAE terminals (ODY-3217-0006) were purchased from Summit through the same site.
EDIT:
1) Buy the terminals directly from Odyssey @ 1/2 the price of Summit & no shipping. http://www.tnrbatteries.com/saetead.html
2) In addition, buy direct from odyssey their Battery Hold Down Bracket, just drill holes in the OEM plastic battery tray. BTW-for extra hold down strength also reuse the OEM battery hold down, it snug’s up perfectly against the Deka on its side - http://www.tnrbatteries.com/odbahodobrbp.html
San, other than local auto parts stores which I have yet to check, where else might one find the adhesive-backed heat protection material? - Purchased from Summit
Thanks again
Last edited by ///DarkSide\\\; May 11, 2010 at 08:39 PM. Reason: Update terminal/hold down purchase info
Old Jan 1, 2010 | 12:21 PM
Silver Bullet C6's Avatar
Silver Bullet C6
St. Jude Donor '10-'11-'12
I'm trying this also...I just ordered my battery. Saving weight up front with a supercharger installed is great. It's nice that it is also on the passenger side where most of the added weight of the centri supercharger was added. Thanks for idea San
Old Jan 1, 2010 | 12:46 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Old Jan 1, 2010 | 01:28 PM
  #33
JayplaySS2's Avatar
JayplaySS2
Nice write up. You're still running the stock manifolds, you will also save a nice chunk of weight when you swap those out for a great header.
Old Jan 1, 2010 | 01:45 PM
  #34
STROKD's Avatar
STROKD
Can this be mounted standing up? I dont have the skill to build custom mounting brackets, even though that does seem to fit real nice on its side and all.
Old Jan 1, 2010 | 01:46 PM
  #35
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
San,
Great info!
I recently swapped out my headers and was disappointed in the weight savings..I weighed every piece I took off with a digital scale and weighed every piece I put back on and the savings was a difference of 12 lbs! Not what I expected....so at least if I do the battery swap thanks to your thread I can save almost 30lbs.
Thanks!
Old Jan 1, 2010 | 01:48 PM
  #36
Stevo92z28's Avatar
Stevo92z28
Yes i know the odyssey can be mounted anyway you prefer. I am actually planning on installing my PC680 this afternoon. I used it in my camaro and it worked great for that. 15lb battery. Easy saving of 20+lbs off the front end.
Old Jan 1, 2010 | 02:05 PM
  #37
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Originally Posted by ///DarkSide\\\
That was I
Thanks again
I picked my adhesive-backed heat material from Napa, but I've seen it at Summit. http://www.summitracing.com/parts/THE-13575/
San
To Lightweight Battery Install (Pics)
Old Jan 1, 2010 | 02:08 PM
  #38
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Glad to help.
San
Old Jan 1, 2010 | 02:11 PM
  #39
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Yes, it can be mounted standing up as there are multiple screw in locations for the terminals. I laid it on it's back to lower the center of gravity. There are boxes available as well.
The mounting bracket is just a piece of aluminum that I rounded the ends of, drilled two holes in and painted. It's really not fancy and I'd like to swap it out when I find something stiffer/better.
San
Old Jan 1, 2010 | 02:14 PM
  #40
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Originally Posted by Neumonic2002
San,
Great info!
Thanks!
I've got LG LTs sitting in the kitchen and some Z06 mufflers and the NPP in a box. I also weigh my parts that I install versus the stock parts and keep all the weights in a spreadsheet.
San
