Service Active Handling - Consumer Action
I tried the following in a relentless persuit to keep my vette.. Tuning to adjust to tire sizes(invo), Doing the clip on the steering column, brakes, grounds checked, new SWPS and even a new EBCM!! This issue along with being modded got me kicked out of a a couple of places... I was postal!
At the end, a local tech at a dealer found the issue was that my car simply did not agree with the exhaust combo. The vibration/tone was too much for the electric sensor. I chose to keep the headers and go with Z NPPs and it completely went away for good!!! This was my experience.
BC
It almost drove me insane(not far from it as is)
Oh and I almost forgot, I replaced my throttle body which was ported. Not much that was left unchecked.(speed sensors, brake lines, calipers). I was told that even the TB has to do with the Active Handling system and it made sense.
If my post helps one person, I'll be happy. I didnt find the scientific solution but it feels good not to be afraid of my car anymore.
I have a couple of those same type of trouble circuits that I had to get too familiar with.
A couple of thoughts trying to think out of the box, if you don't mind listening:
Have you tried to desensitize the YAW sensor. If it that sensitive to excessive vibrations, find a material that you can use to keep it firmly mounted but more isolated from any additional vibrations from external mods.
Check the female pins for proper tension on the male pins. This killed me on the WSS issues. Come to find out, most of the female pins had a very poor tension on the male pins and any vibration or harness movement would cause a WSS DTC. Ive found numerous bad female pins. You can use a dental pick to bend down tung if you find a loose female pin.
Heres the male pin that I used to track down the issue:
Bad female pin on the right WSS connector:
Hope this helps
Bill
You know, I had the same idea about padding the yaw but never got around to it.Knowing that I could make it go away by removing my exhaust gave me a great sense of relief. I thought to myself, at least I have some control and know its not something that will get worse. Sucks to be defeated by a gremlin!
Thanks for the info Bill! Nice write up with the pics and all. I may PM you tomorrow to tell you why I was messing with the connectors in your write up 5mins ago. I fear the gremlin but I suspect it may be my allignment.
Thanks for serving and ( kicken ***) and putting your life on the line!!!!!
Any time you need HELP,,, you know where Im at!
Bill
So without being fully up to speed on this issue, let me just ask one silly question.
Why not just remove the connector(s) that are suspect altogether by cutting them out and then solder and heat shrink the wires together so there is no more question about possible faulty contacts causing the issue?
By the way, I'm not sure I agree with the earlier comments to use dielectric grease on the connector pins. Dielectric grease is really used mainly to keep water out of connectors and prevent oxidation, and this is not the problem here. Dielectric grease on pins can actually make the problem worse, since it is an insulator and it will also lubricate making movement/vibration of the pins even easier. There is no worry of water getting in this connector and this would not be a good application to put it in since it could act to prevent metal to metal contact and make things worse. I would recommend putting the connectors together clean and dry.
http://s680.photobucket.com/albums/v..._AV8R/?start=0
The sad part is that the harness in question plugs into the Steering Wheel Speed Sensor (SWPS). Theres on pigtail to solder the harness to. I suppose that you could dissect the SWPS and remove the pins and replace them with wires. Not many people are willing to destroy a $200+. part to experiment with. If mine was failing daily, I might try that but, so far my repair is working well. (Imagine the sound of knocking on wood
)Heres a picture of the sensor and the harness connected to it:
BC
As I posted above, I would NOT recommend putting any dielectric or silicone grease on the pins or connector. Grease is only going to make the problem worse. The connector should be put together clean and dry.
The system uses wheel speed sensors, a brake pedal position sensor, brake fluid pressure sensor, steering wheel position sensor, yaw rate sensor, and a lateral accelerometer sensor.
My experience with other vehicles that have had ABS related problems is that they are usually caused by a bad wheel speed sensor, and they do seem to be prone to failure. I'm not saying that is the problem here, but it is something to consider.
Intermittent problems are usually traced to a bad contact or connector somewhere in the system. There is an additional connector shown on the wire diagram that both the steering wheel sensor inputs, and yaw an lateral accelerometer signals go through. I don't know the location of this connector, but it is shown on the wire diagram. That would probably be something worth tracking down. In addition to checking the signal paths, I would probably also check the 5 volt reference signal that come from the Electronic Brake Control Module to both the Steering sensor and the accelerometers and make sure it is good.
If my car were exhibiting this problem, I would locate every single connector associated with the system and carefully inspect each one under magnification and test for loose pins and make sure all connections were solid. I suspect all these problems will be traced back to one or more bad connections. It's just a matter of locating and fixing them.
1. the yaw rate sensor
2. the steering position sensor
3. the lateral accelerometer
This differs from the three things the stealership told me
1. the yaw rate sensor ( which I had them perform... did not fix problem)
2. go through each pin on the BCM and see if one was pulled out
3. my 345/30/19 wheels are too big and I need to go back to stock sizes.
This problem WILL be corrected... sooner or later...
-Car pulls right constantly except at lower speeds, worse at high speed
-"Service Active Handling" (DIC)
-"Service Vehicle Soon" (DIC)
-Tire pressure warning, also in DIC (too high on opposite corners)
-The little car with skidmarks icon on the dash is lit up all the time (AH?)
-Right blinker stops working sometimes. Totally stops working.
-Cruise control won't work
-Reverse lights won't come on
I have yet to check fuses, assuming there was more to it than that. now this thread makes me think I'm right. Tire pressure can be fixed easily.
I did have a dead battery recently, but it's good now.
I had the car at the dealer for a $79 alignment, car still pulls hard to the right. Some fix that was.
Right now, I can honestly say I've never been more PO'd at a car and the a-hole who sold it to me....assuming he knew all this stuff had been occuring. But then, he only drove it about 1500 miles in his 1 year of ownership. Maybe he had it quick-fixed and cut his losses by selling it to me.
So has anyone here had the combination of problems I've listed above?
