Should I machine rotors?
Old Jun 3, 2009 | 08:18 AM
Schlitz-C6's Avatar
Schlitz-C6
Default Should I machine rotors?
I just bought a 2005 Z51 and the brakes are squeaking. Thanks to this forum I found there was a bulletin from GM on it and I am getting the dealer to replace the pads free of charge. The bulletin states that you do not need to turn the rotors but the bulletin is from July 2005.
The car has 24K miles and I feel nothing in pedal that leads me to believe I need to run the rotors. The dealer of course wants me to do so but I dont know what the right choice is.
What do you guys think I should do?
Thanks a lot!!
Old Jun 3, 2009 | 08:33 AM
Walt White Coupe's Avatar
Walt White Coupe
As long as the stopping surface is relatively smooth with no deep grooves then there is no need to turn the rotors.
Old Jun 3, 2009 | 11:43 AM
TEXHAWK0's Avatar
TEXHAWK0
If there is a lip on the edge of the rotors, you might consider letting the dealer at least turn the rotors to remove that. If the rest of the surface is smooth and without any major grooves, take the minimum amount off the rest of the rotor face.
Old Jun 3, 2009 | 11:52 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Machining the rotors can potentially shorten their life so I would not do it unless you see the deep scores or are feeling pulsing in the pedal. When you turn 'em you remove metal therefore reduce life, also the heat generated during the turning can change the properties of the metal and shorten life that way.
If it ain't broke, no reason to fix!
Old Jun 3, 2009 | 02:13 PM
Schlitz-C6's Avatar
Schlitz-C6
Thanks a lot everyone. I figured if the pedal felt good with no ushing back or pulsation I should wait till the next time I do the pads. Plus it will make the visit cost free as the warranty is paying for the pads.
Which with me driving will be about 1 year, maybe 2.
For those out there reading, I had complained about the squeak and the dealer told me not to worry about it, this forum informed me of the bulletin and I had to point it out to the dealer, whom still tried to talk me out of it. Why I do not know............
Thanks again!
Old Jun 3, 2009 | 03:27 PM
VET4LES's Avatar
VET4LES
I'm surprised your dealer is doing this free of charge. GM stopped doing this several years ago. They determined the squeal is normal.
Old Jun 3, 2009 | 03:31 PM
Walt White Coupe
Maybe Obama is more customer friendly than the old GM.
Old Jun 3, 2009 | 03:41 PM
Schlitz-C6's Avatar
Schlitz-C6
Yeah, I had them check em and they said the squeak was normal but when I found the bulletin they agreed to do it. They are doing it Thursday morning.
To Should I machine rotors?
