My tach is 100% blocked from my view because of the way i have my seat and steering wheel set up. (do not have HUD in my car). so whenever i race i have to slouch and look under the steering wheel to see when i am going to hit 6500rpm.. this is kind of annoying and dangerous while racing.. I was thinking of adding what i call a little pen light somewhere to alert me (not blind me) when i am reaching redline. has anyone added one of these? if so i would like to know brand, rpm you have it set at and location you mounted it in the car..
My apologies for going off-topic, but how can you possibly set the seat and the steering wheel so wrong that you can't even see the tach at all?
I would be seriously worried that the way you've set the wheel up is going to seriously injure you if that airbag ever deploys in a crash...
well i do not know if this addresses your concern or question but: i am
6' 4'' tall so i have to put the seat back all the way to be comfortable with the pedals. then i like the tilt wheel lowered all the way for comfort. when all is said and done the top of the steering wheel blocks my view of the speedo and tach right at the very top of both guages. also maybe this will clear things up a bit.. when i talk about racing i do not mean on a track of any kind where you might be more inclined to sit up. i am talking about comfortable street mode and racing..
hey guys, just went to the Raptor web site... that is just what i am looking for. thanks to all for the posts.. is it real simple to hook up?? where do you pick up the tach lead wire in an 08 c6?? does it interfere with the operation of the factory tach??
From: Greater Detroit Metro MI, when I'm not travelling.
tks, dal
The airbag is designed to catch the top of your chest in the event of a collision; with the wheel "lowered all the way for comfort", it is going to hit your abdomen, where that 350 mile an hour, explosively driven bag will most likely rupture your spleen, damage your kidneys, liver, etc... Please refer to your owner's manual about how to correctly set your steering wheel height; when properly set, you will be able to see your tach, and the airbag system will work effectively, potentially saving your life
tks, dal
it is fairly simple to hook up. I placed mine near the rearview mirror and set it around 6200 RPM. I followed this forum member's installation post...
Please refer to your owner's manual about how to correctly set your steering wheel height; when properly set, you will be able to see your tach, and the airbag system will work effectively, potentially saving your life [/QUOTE]
while your post might have been considered off topic (as you stated), i must say i appreciate your comments and concern. it is nice that this forum is filled with informative and caring people... thank you....
excellent. funny what some of you guys consider "fairly simple to hook up".. i have not ready thru the write up yet but it looks like he tore his car apart to install this thing.. to me "fairly simple" is something you plug in.. thanks to all for the info. for safety and more accurate shifts i will be going with this raptor unit..
I take it you don't have HUD which already has a shift indicator?
the shift light on the HUD sucks i never see it, they should have made the whole screen light up or invert the colors or something so it's noticable.
even though the "UPSHIFT NOW" displayed in the DIC is lower your periferal vision still picks it up and it's alot more noticable then the shiftlight on the HUD.
I guess "fairly simple" is relative. However, you only need to remove the lower knee panel on the right side which is held by screws and find the right tach wire. The rest is running the wires, etc. It took me about an hour to do.
