Cut Front Bushing ???
Old Jun 23, 2009 | 12:36 PM
Snake Slayer's Avatar
Snake Slayer
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Default Cut Front Bushing ???
I recently lowered the front of my 08 Z51 coupe by cutting the front bushings. I cut the bushing even, but for some reason the fender tire height on the left front is 1/4 of an inch lower than than the right. The right bolt is maxed out and I have attempted to raise the left side but I am still of by 1/4".
Will a 1/4 of an inch cause any suspension issues? my next option is to probably purchase delrin shortie bolts.
Old Jun 23, 2009 | 12:43 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
go and sit in the passenger side a couple times.
Old Jun 23, 2009 | 01:45 PM
c6 batmobile's Avatar
c6 batmobile
It shouldnt cause any problems but if you cut the bushings even it should sit even. Are you sure all the threads are out of the bolt? sometimes they dont go all the way in because of grime and what not.
Old Jun 23, 2009 | 02:35 PM
Snake Slayer
Cruise-In V Veteran
I am sure on the bushings but will recheck the threads on the bolts.
Old Jun 23, 2009 | 04:31 PM
LEAVINU's Avatar
LEAVINU
Could be the alignment. My car is actually aligned to where the driver side sits 1/4 higher than passenger, but once I sit in the car it evens out.
Thats a perfected alignment.
Old Jun 23, 2009 | 04:32 PM
LEAVINU's Avatar
LEAVINU
I drive it like I just robbed a bank
Really, looks like your headed to the grocery store in that pic.
To Cut Front Bushing ???
