Engine Sludge Clean Up: Silly Question?
Gues what the guy who "owned a shop back in Oklahoma" recommended...
Transmision Fluid!
Yep, Transmision Fluid. He recommended 1 Qt of Trans Fluid, to fresh oil and check the color every hundred miles or so. When the oil starts to turn dark, change it. Then repeat the process until you can run at least 1K miles without discoloration.
I mentioned my concerns for gaskets, internal components, etc. but he seemed to beleive there were no issues.
Having heard this, I couldn't wait to run it past the brightest minds I knew. They weren't available so I thought I'd post the question here. (Just kidding!).
So, has anyone ever heard of or done such a thing?
If so, what was the result?
Transmision Fluid!
I knew an older guy who insisted on 1 qt of atf in the crankcase every oil change.He had a 51 chevy truck, straight 6, over 150,000 miles on it. The motor had never been opened and it was silent! I have used atf with oil as a flush or to free up a sticky lifter, but then changed to all oil thereafter.
Besides, we run full synthetic from the factory. As long as your oil is changed regularly there should NEVER be sludge inside your engine. Now inside your intake manifold might be a different story
Also, blow-by (oil getting past rings) isnt affected by catch cans or breather cans because with blow by the oil gets into the combustion chamber past the rings and there's no way to catch it in a can or otherwise.
As far as crank case build up, change the oil when you're supposed to before it breaks down and leave trans fluid for the trans.
older oils didn't have detergents that trannys have, new oils do have detergents, so doing that today, is just a waste
-carl
-carl
Ive had numerous LS engines opened up. Ive NEVER seen any SLUDGE! The castrol GTX commercials try to play on your fears to take cash out of your pocket. Use a GOOD synthetic changed when the DIC tell you to and you will NEVER have any S L U D G E issues!BC
If you are really worried, I'd use this which is actually designed for this application and you don't have to run around with it in your car:AMSOIL Engine Flush (product code AEFCN)
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Transmision Fluid!
Use a good synthetic oil, and don't use any additives. Modern detergent oils changed regularly will keep the motor clean.
Yes, there are engine flushes available, but if done properly, and with enough precaution, using ATF to flush an engine can be highly effective.
As was stated, getting all that junk loosened up and moving can be potential restrictions, but that is where precaution comes in.
Never letting things get to this point is ideal, but it's a practice that when needed can be effective.
I dont think GM is the be-all engine designer and I definitely dont think that they designed the best engine for the current corvette. Current blunders of GM's include: An oil return system that allows the engine to ingest huge amounts of oil causing massive amounts of carbon build-up, a gas gauge that jumps between full and empty, a delaminating top, a harmaonic balancer that falls off the engine because it didnt fit, an active handling system that goes bad because they put a bad connector in the streering column, and lets not forget the famous steering column lock that just locks on some cars when they are being driven. I have even seen some cars filing for servioce because the active handling system made them hit the car to the side of them in another lane when it locks up a single wheel's brake.
I'm sorry if I dont think GM does it best.
