Tire size question
Old Jul 14, 2009 | 12:40 AM
werner8550's Avatar
werner8550
Default Tire size question
can i put 265/40/18 front's and 305/30/19 rear's ps2's on my C-6 std. stock wheels with no clearance or computer problems
Old Jul 14, 2009 | 10:34 PM
werner8550's Avatar
werner8550
help
Old Jul 15, 2009 | 06:49 PM
werner8550's Avatar
werner8550
Old Jul 15, 2009 | 07:47 PM
Sparo2's Avatar
Sparo2
I had 255/35/18 fronts & 305/30/19 rears before i did my ZO6 conversion. I don't see why not. Might want to stay close to the diameter of the stock tires. Otherwise you might have issues w/ your AH & ABS
haljensen's Avatar
haljensen
You can do it, but why would you want to? 20mm wider tire on stock width wheels can be done but handling will suffer.
Just like you could put a size 9 foot in a size 11 shoe, it can be done.
The size stagger F to R would be wrong also, up 20mm with the same aspect ratio as stock in the front and up 20mm with a lower aspect ratio in the rear will probably throw off your Active Handling.
Compare stock diameters to your diameters on;
http://www.miata.net/garage/tirecalc.html or
http://www.1010tires.com/TiresizeCalculator.asp
Old Jul 15, 2009 | 10:42 PM
werner8550's Avatar
werner8550
my question is since i have 305/30-19 on the back what is my best choice for the front size ,where is the spedo reading coming from trans ? how do i calculate the spedo change with both front and rear size change THANKS FOR THE CALCULATOR INFO VERY INTERESTING IS THERE ANY WAY TO CALCULATE ALL 4
Old Jul 16, 2009 | 09:10 AM
haljensen's Avatar
haljensen
Speedo reading is from a reluctor on the ring gear in the differential, the only way it can be changed is by a computer tune.
Previous posts have said that if you keep the same diameter difference between front and rear that the A/H won't interfere. IE; If you change the R. diameter by 0.50 inch then change the F. by the same amount.
I don't understand your question about calculating all 4.
Old Jul 16, 2009 | 11:45 PM
werner8550's Avatar
werner8550
so does that mean that the rear wheel speed determines the speedo reading
Old Jul 17, 2009 | 12:04 AM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Not the way I read it. The speed would be calculated by the ring gear speed. The wheel speed will vary depending on the wheel/tire size.
San
Old Jul 17, 2009 | 08:07 AM
Dan Wendling's Avatar
Dan Wendling
Default How is the speed computed?
I am not sure but I think the speed as displayed is computed by the front wheels using the wheel speed sensors of the traction control system. If it were not then when you are spinning tires in first gear the transmission controller would shift you directly to 2nd since clearly your wheel speed is far above the 1->2 shift points.
I think you can see this by looking at the speed display when doing a burnout.
Old Jul 17, 2009 | 09:16 AM
haljensen's Avatar
haljensen
The ring gear has the sensor for the speedometer.
If you change rear gears you DO NOT have to change the speedo, if you change tire size you DO have to adjust the speedo.
Old Jul 17, 2009 | 11:24 AM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
The car has problems when the tire's rolling diameter is changed. This is based off of the four wheel speed sensors based inside the wheel bearings.
You have roughly 5% variance to work with here between front and rear as the car does have to account for tire wear. You can go shorter or taller, again slightly but you need to keep the rolling diameter close to the same.
For example I have a 255/35/18 front and 305/30/19 on the rear. While both of these are slightly shorter than stock, they still read correct up to a tested 150 mph.
Now if they are different this is going to grow with speed, so if the car does not see speeds over 125-140 mph with the TC/AH on no worries. If you are going to run the car over that with TC/AH the car doesn't care so it isn't going to effect anything.
Old Jul 17, 2009 | 03:43 PM
Silverton's Avatar
Silverton
Anthony,
I'm don't understand your 5% number. It was my understaing that the OEM "rake" is 1.2 inches, where rake is the difference in height of the rear wheel and the front wheels. As long as this rake is maintained the AH/TC doesn't car. Is that correct?
Alternatively, it has been stated on this forum that HP-tuners can be used to allow use of "any" tire combination front-to-rear.
Old Jul 17, 2009 | 03:57 PM
Former Vendor
Originally Posted by Silverton
Anthony,
Rake, or stagger, is part of it. The 5% number is the actual change in tire height, again the car has to be able to accept a change in height if you have bald rear tires and new fronts.
If you want to get right down to it, the car is going to be looking at the rolling diameter of the tire or rev's per mile. Tire height is a quick and dirty way to do it though.
Old Jul 17, 2009 | 05:51 PM
FUNTRUN's Avatar
FUNTRUN
To answer the origional question. Many users on the forum have run 265/35-18 fronts and 305/30-19 rear size tires on the factory wheels and had no problem. Yours may react differently but I was planning on doing the same thing until I got my wheels widened.
To Tire size question
