2005 4 speed auto - gears ?
Old Jul 16, 2009 | 09:22 AM
Ragtop 99's Avatar
Ragtop 99
Before you run out and buy gears, find someone with a 3200 - 3600 stall in the car and go for a test drive. You'd be surprised how hard you can launch the car with a good stall. It also keeps the car from falling flat on the 1-2 upshift so it helps from a roll too.
Old Jul 17, 2009 | 01:58 AM
Bkbulldog's Avatar
Bkbulldog
It goes the same for the A4's but they get the 3:90 gears instead of the 3:42's
You will definitely get a beast back
Chuck
Even chuck says 3.90s if you want a beast
Old Jul 17, 2009 | 06:30 AM
REVAK's Avatar
REVAK
Originally Posted by tutin
What is the ratio on the standard auto 4 speed 2005 corvette gears ? Would it be a good idea to go for a higher ratio to get some decent power increase in a low budget ?
My early-year plan was to go Lingenfelter supercharger, but the economical situation affecting my business says differently, so I'm thinking of doing some cheaper mods instead.
So what do you think. A decent cold air induction and a higher gears ? What ratio for the 4 automatic ? Don't want to change the exhaust as a decent one would again settle at around 1.5k
Thanks for your advice
I went from 2.73's to 3.73's in an A4 Z28 years ago, favorite mod on that car. If you care to go the math , you will find the ratios in your A4
are perfect for 3.73's.
Old Jul 17, 2009 | 10:29 AM
Ragtop 99's Avatar
Ragtop 99
Originally Posted by REVAK
I went from 2.73's to 3.73's in an A4 Z28 years ago, favorite mod on that car. If you care to go the math , you will find the ratios in your A4 are perfect for 3.73's.
I had them too. The C6 tire diameter is larger than the Z28, so 3.90s in a vette are pretty even with 3.73s in the F-body.
Old Jul 17, 2009 | 10:38 AM
TESTOSTERONE C6-R's Avatar
TESTOSTERONE C6-R
The higher you go, the more wear you do on the tires.
Thats just the nature of the foot.
Old Jul 17, 2009 | 11:34 AM
tutin's Avatar
tutin
The foot issue is a serious one So far a set of new tires lasts no more than 3-6k miles with me.
Gents, nobody said anything about the top speed. Let's say I go with 3.73 - what happens to the top speed ?
Do I need to consider anything else, besides the gears themselves. This mod looks too sweet to cost only $250. Am I missing something ?
Old Jul 17, 2009 | 02:10 PM
Ragtop 99's Avatar
Ragtop 99
1) installation cost
2) tuning to optimize shift points
Old Jul 18, 2009 | 03:08 AM
rockitt66's Avatar
rockitt66
So why is it that GM didn't go with higher gears from the factory? Is it because of all the other upgrades that would have to go into stabelizing the higher gears, like all the upgrades on the Z51?
BTW this is a great thread. Thanks for starting it and to all who have added info to it. Its has helped my insight greatly on this mod.
Old Jul 18, 2009 | 03:32 AM
LS1LT1's Avatar
LS1LT1
Mostly because of fuel economy and noise restriction (numerically higher gears = higher RPMs = louder across the board) reasons. Emissions/clean air play a role in there as well I'm sure.
Old Jul 18, 2009 | 03:38 AM
rockitt66's Avatar
rockitt66
Hey thanks for the info.
Old Jul 18, 2009 | 11:08 AM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Chuck
Thanks fellas....
If you've got an automatic VETTE, there's only one place to go!
Give me a call any time!
Chuck CoW
Old Jul 19, 2009 | 03:03 AM
tutin's Avatar
tutin
Chuck, I'd love to, but I'm in the EU. Not many garages here tune or know anything about Corvettes.
Old Jul 19, 2009 | 12:45 PM
  #33
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
Default No problem!
NO PROBLEM!
Lately, I've been selling the EFI LIVE tuning package I use to customers outside of my area or outside of the country so that they can take advantage of my mail order tuning.
With this tuning package, I can remote tune just about anything you might have.
We can e-mail the tunes back and forth to get you running right with your mods.
Chuck CoW
Old Feb 23, 2012 | 11:21 AM
  #34
Mitko's Avatar
Mitko
7th Gear
When you have 2.73, on top speed your engine will be on the limite of power. When you put 3.42, on same high speed your engine will turn with more RPM. So the top speed have to be same or a little less than before.
Maybe I'm wrong but always was the same when changing the diffs. (not on Vettes but any car it's same)
After all lets see if Tutin will work on the C6 Vette or will spend some USD for an oldtimer!
Old Feb 23, 2012 | 11:28 AM
  #35
Dragracer_Art's Avatar
Dragracer_Art
Well, there is one other chance for someone with a non Z51 2005 C6 automatic to still have the 3.15 gears...it was also a freestanding option as well as part of that Z51 package.
Check your build sheet (a white sticker with code numbers on it in the glove box or center box I believe?) and see if it says GU2 (2.73s) or G90 (3.15s).
EGGZactly.
I have an '05 base model with no Z51... but I DO have the 3.15 gears.
Found that out by checking the RPO codes in the glovebox.
Old Feb 23, 2012 | 12:08 PM
  #36
Vette_DD's Avatar
Vette_DD
OEM gear and rear axle ratios for C6s.
Old Feb 23, 2012 | 12:47 PM
  #37
stanger383's Avatar
stanger383
St. Jude Donor '09
most likely your top speed is DRAG limited.. Not enough power to over come the vehicle drag(wind, rolling resistance, yada yada yada) I would say, having said that, that you could possibly even increase your top speed because at the same mph(lets say 175.... IDK what it is) you will be shifting your RPM higher in the power band.
Old Feb 23, 2012 | 05:55 PM
  #38
Justasheet's Avatar
Justasheet
Originally Posted by sweetc6
Forget the 390 gears and go for the 373 gears.Check the forum and you find most A4 have 373 gears.
and don't forget the stall.
Jeff
Old Feb 24, 2012 | 06:32 AM
  #39
Mitko's Avatar
Mitko
7th Gear
Your Vette will reach the top speed on the 4th gear, on the 6 gears models the top speed can be reach in 5th gear. As you see the tranny ratio it's almost the same. Top speed the RPM in your car will be no much higher than before and the top speed will be maybe same or little less. As stranger 383 says the Drag it's the factor to the top speed limit. The DRAG and the POWER are like TOM and Jerry... always fighting. But as you know in Bulgaria the places to drive with top speed are 4 or 5 and maybe will be not a problem if you can't reach it.
